cwah
Hello all,
I noticed that every time i install a marathon plus tyre, my wheel becomes untrue. I tried few times to remove the tyre and see if there is a bad tube fitting but I can't really find any.
I tru-ed the rim first to make sure it's not a problem with a bend rim, when I install the tyre afterwards it gives this:
[youtube]C_T5y6U_-Is[/youtube]
You can see a little gap on each wheel revolution near the valve...
Here's the wheel from far:
You can also see the reflective strip slightly lower near the valve...
What is wrong with the wheel? Is it because I installed a 26x2.00 tyre on a narrow rim? I can't fix the problem and I have this issue with all my marathon tyres...
Shall I pop to the bike shop or will they also be useless as usual?
Thank you
Thank you
