Callbrin said:How do you know what kind of battery to get i.e. Discharge Current Rating. How would I know what rating I needed so I dont end up overheating and/or killing the batteries?
Thanks in Advance
SirLongAss said:If it can be done, buy a battery with a constant discharge current higher then what your ebike can is rated for.
If you are building your own battery, use the manufactures specs for charging and discharging.Callbrin said:SirLongAss said:If it can be done, buy a battery with a constant discharge current higher then what your ebike can is rated for.
Where do i find that rating? the motor controller? or is it based on the wattage?
e-beach said:If you are building your own battery, use the manufactures specs for charging and discharging.Callbrin said:SirLongAss said:If it can be done, buy a battery with a constant discharge current higher then what your ebike can is rated for.
If you are purchasing a already built battery pack, confer with the manufacture about the specs of the pack.
If no specs are given by the manufacture, don't purchase the batters or pack.
Callbrin said:e-beach said:If you are building your own battery, use the manufactures specs for charging and discharging.Callbrin said:SirLongAss said:If it can be done, buy a battery with a constant discharge current higher then what your ebike can is rated for.
Sorry I meant how do I find how much my ebike would draw from a battery pack so i dont get one too underpowered
Errr ??... That assumes he already has the battery, and that the battery is able to output more amps than the system requirements !e-beach said:Or get a cycle analyst from ebikes.ca or if that is out of the budget, get a rc watt meter from ebay and us it to find your max amp draw.
Hillhater said:....
Errr ??... .....
