maanebedotten said:I wonder how voltage influences current capabilities as I am in the process on standardizing all my batteries to 52v/14s. Does this mean I can safely push more amps than I did on 72v as long as I keep the watts the same? Or is it a case of amps is amps no matter the voltage?
Your system will need to be capable of handling the higher battery-side amps it will take to create the same wattage. You can figure the new current by the inverse voltage ratio times the old current.
Meaning, your battery itself must be able to sustain the higher current, and supply the higher peaks, so if you were already maxing out the 72v battery, the 52v will have to be even bigger in capacity for the same c-rate, or use higher c-rate cells.
The BMS and interconnects also have to handle this higher current.
The wiring from battery to controller will have to handle the higher battery-side current, too, as will the ocnnectors.
The motor side stuff may already be fine--depends on whether the controller is going to use higher phase amps or not, to do the same job, and whether that stuff is already able to handle it.
