I managed to short out the dc power out connection to a front light connected to a cycle analyst V3-WP. Yes, I did something stupid. Everything still works as it should except that the multifunction switch power on/off button no longer works and when charging the battery on the bike, the CA stays on. The other buttons on the MFS are working correctly and there are no issues with the throttle or PAS to the motor. I've tried searching but haven't found an answer as to exactly what I might have done to the circuit and whether there is an easy fix or even to know whether the problem is with the CA or the MFS at this point.
What I've tried so far:
Disconnect the battery and controller (Z9 baserunner) from the CA3
Reinstalled the firmware on the CA3
Checked the controller for faults-none detected
Disconnected and reconnected the MFS
Any guidance/help greatly appreciated.
