Ride1Up 700 Series: An upgrade journey (Now with wiring diagram)
As I continue to tweak and peak my motor by adjusting the Feedback Bandwidth Tuning, my motor no longer operates. I can heard the clutch engaging. I hear and feel the planetary gears moving. No grinding noises. In the PhaseRunner Suite, there are no registered faults. The hall sensors are operating as intended. I did notice that some values were adjusted when I changed settings. I tried auto tune, no luck. The motor fails the spin test. I also tried to reset the BaseRunner. No luck either. I’ll continue to iron this out when I have more time (aka, when the kids go to sleep). Lots of dadding today. Got my V7 Grin torque arm on though.
A $15 generic controller, a $10 generic throttle, and that crappy bike can be back in business better than new.
if the motor is not spinning at all, it could be a connection fault, or something phsyically wrong with the BR, if a reset of all the BR's settings and a power cycle didn't fix it.
If there's a connection fault, the BR won't be able to detect the motor (probably the same if a FET failed).
If the BR is not connected to a battery, and you put your multimeter on it's battery input terminals, spinnning the mtoor backwards will generate soem volttage. If it does, and it doesnt' feel abnormally draggy, then there's probably nothing wrong with the FETs, and probably no connection faults to the motor. If you can guesstimate the RPM you're spinning it at, and know the kV of the motor, you can guesstimate the voltage you should see if all connections and fets are working. If one phase is missing, you should see only 2/3 of that.
I’ll have to check closer when I have more time to. Probably this weekend. I have quickly checked the dashboard area of the PhaseRunner suite and the halls all toggle properly. I hope it’s not a FET is the BaseRunner. I do have my other KT setup that I can use to verify the motor spins.
Now I really need to get off my butt and install my torque sensor. It has not only been the longest time I’ve been off my bike, but now the longest since I’ve made any tweaks or upgrades on it. Thanks for the motivation.
I said the same thing to myself when I was installing the temp sensor. I swear, I ordered that thing almost a year ago. Haha
I’ll have to check out your thread again. I’m curious if you’ll have a difference in BB spindle length and how that could effect your chain line.
You can hear the motor spin and gears turn, but the wheel is still. Could it be running backwards? That's fixable.
I just bought some 35E's. I was a bit concerned by 18650batterystore's 8A peak spec, although a 32A 4P is far more than I need.
I haven’t had time to troubleshoot any more. Hopefully, I’ll take another look tonight. Yes, I hear the gears, but no wheel rotation. I’m really hoping this isn’t a hardware issue.
I feel like 25A was a nice maximum for this pack. 30A was fun, and much better on hills. Just that drawing 30A used about .5v more than 25A, for my commute.
I usually charge after my second day of commuting, 16-17 miles. On the third day, I find myself getting close to LVC, if I don’t charge after the second day. If I have to make a stop on the way home, on that third day, I may not make home. Running a 30A max, I was closer to the LVC.
I can’t charge at work, because I work in multiple locations throughout the day and can’t monitor the pack while charging.
I didn’t hear any noise, in the motor. Other than something spinning. My first thought was to open the motor, but given the time, I opted to check my settings. I’ll have a look at that key as well. What I did hear spinning was what sounded like the planetary gears rotating in the sun gear. You very well may be right on the money.
If thsi is whn operatignj the controller, then the motor *has* to be the thing that's spinning, because the controlelr can't spin the gears without spinning hte mtoro. ;)
In that event, the most likely thing is that the mtoor is spinning backwards, so it wont[ drive the wheel becuase of the clutch.
the next most likely thing is the gears are stripped so they can't driv eanything. or the clutch is broken; like i had on a fusin--a tiny crack from the corner of one of the roller ramp reewcesses let the cluthc flex enough to not put any pressure on the rollers so it wouldn't drive the planets.
Orwhatever secures the sun gear to the rotor isn't there or isn't working, so the sun gear is not able to transfer motor torque to the planets and ring giear. Alternately the ring gear could be unsecured, bnut that's got so much surface area it would probably still friction drive the motor casing.
My money is on a sheared woodruff key.
Time will tell. I’m planning on opening the motor tonight.
Edit: I opened the motor and it’s not the keys fault. The key is intact and gears look good. I can rotate the wheel and hear the gears engage smoothly
I put the motor back together and tried a bit of throttle. The motor whirred slowly, as moving through water. I’ll try other software things another day.
So, the motor is fine. I tempconnected the previous KT system. Motor spins up fine. I tried walk mode, then with PAS. I didn’t have a throttle to test with. Motor spins as expected in all PAS levels. I think the motor temp sensor is working as well. It normally reads 50F when there is no sensor, now it reads 59F. I can verify later, but the bike is upside down and there is no way to put a load on.
Contemplating to put the KT system back on and working with Grin support at another time.
After some more loading default parameters to the BaseRunner, autotune will NOT spin the wheel. I also tried to reverse rotation. No luck.
I’m also considering using the CA with the KT controller. I’ll be on vacation all next week, so I’ll have time to consider which direction I go. Until then, the bike will be upside down.
UPDATE: Turns out 59 is what’s shown when the temp sensor is not working. Temp readout probably won’t work. Just like @AHicks suspected.
if the mtoro works ith the kt controller thne something in the br isn't allowing it to spin it in the forward direction, only backwards.
it has to be spnning it backwards because you can hear it spinning, rihgt?
if it's spinning at all and the wheel isn't spinning, it must be spinning backwards.
if it were spinning forwards but not spinning the hweel, the same thing would happen wiht the kt controller.
since it doesn't, it can't be spinning forwards with the br.
Really strange. I just accessed my BaseRunner. I’ve decided I will install the KT system again. This green epoxy, I don’t remember that ever being there. It’s only on the BaseRunner and not inside the frame. As if this material seeped out of the BaseRunner.
I’ve reached out to Grin for more guidance. Sent them this photo and linked to this thread. I know they are busy this time of year, so I’ll wait to hear back about what to do next. Thanks for all the input!
Grin got back to me. They say the green liquid is thermal paste and of no concern. They also say that the stutter is normal at low speeds and that I should adjust throttle ramping to minimize the condition, or try a sine wave controller.
Also seems like reloading the default parameters for the BaseRunner is separate than loading default parameters for the motor. I thought loading default parameters for the BaseRunner would override, and default, the motor settings, but that’s not the case. I’ll try this one last time, then I may toss the BaseRunner and wire my KT controller for the cycle analyst.
Well, the BR *is* a sinewave controller (and FOC, too).
So you might want to find out exactly what they meant by that.
Hopefully you mean toss it into the spare parts bin.... ;)
Wow. Bike spins now. I loaded default parameters for the Shengyi SX Standard Wind. I’m glad the controller works. I think I’ll keep it now. Lol.
Will start moving along locking the clutch to introduce regen. I already have the torque arm installed.
I just need to buy my buddy some beer and he can weld the clutch for me, since he has all the equipment. Maybe he will let me practice and I can do it.
Went to my buddies house today. His kid welded the clutch for me. Came out nice. Now to set it up.
Update: regen is mostly set up. I did a quick glare over the info before I went to bed last night, and a bit more this morning. I really like it and I just need to learn how to use it better. Motor temp wasn’t too off from before. I’m making the exact same commute as my previous temp readings. Here are some pics.
One minor thing that has been bothering me is the voltage readout. I see the key switch and the Cycle Analyst readouts, and when I’m connected to Pasherunner suite, all 3 readouts are different. I trust the BaseRunner the most, since my battery is directly connected to it. The CA and key switch are wired after the BaseRunner. CA and key switch read lower voltage than BaseRunner. I contacted Grin and got an email back within an hour! They advised to raise the VScale (in the Calibration Setup Menu). My VScale was at 30.56 and I raised it to 30.95 and now my CA displays the same voltage as the BaseRunner.
Easy fix and kudos to Grin for the quick response.
I’m going to replace the key switch with one that has a 2 position switch instead of the voltage readout. It’s hard to read the voltage readout on the key switch anyway.
One minor thing that has been bothering me is the voltage readout. I see the key switch and the Cycle Analyst readouts, and when I’m connected to Pasherunner suite, all 3 readouts are different. I trust the BaseRunner the most, since my battery is directly connected to it. The CA and key switch are wired after the BaseRunner.\
FWIW, when just sitting there, it doesn't matter what order anything is connected in, they are all in direct parallel and have the same votlage actually present.
If measuring under load, then resistance of connections can cause vvoltage drop acoross them, but that doens't apply wiht no current flow.
And it is unlikely to be as accurate as either of the other info sources, and is only calibratable by disassembling it and replacing at least one resistor somewhere with a pot, then tuning it with a known range of voltages. (which resistor is something you'd have to find out during reverse engineering of it's internals...but it might not *have* any of this external to the voltmeter chip inside which usually also drives the dispaly and may have no parts outside of the chip itself).
I found this great site detailing the Samsung 35E cell.
I don’t feel bad about setting my max battery amps to 30, knowing my battery can handle it. My previous runs, at 30A, were to see how my BMS responds and if it’ll trip, it never did. To see if there is noticeable difference between 25A and 30A, I can tell and I like it. And if there was any more heat added to the motor, which seemed negligible and makes sense since I wasn’t upping the phase current.
I noted my last cycle when set to 25 amps. Rode about 25 miles on that last cycle. I could’ve gone a bit longer, but I have no way to be present when charging my bike at work, so I avoid that situation and charge when I see voltage drop around 46-45v. That way, I can ensure lll have enough juice, after work, to get home and maybe stop by a store to pick up something.
I’m watching the heat closer, right now, due to regen braking. I really like how braking feels now. Temp goes up slightly, in the afternoon. Got up to 82C, Ambient was about ~25C.
