Kmob1 said:I believe mid-drive kits are the most efficient???
spinningmagnets said:D'oh!...ya beat me to it!
d8veh said:Kmob1 said:I believe mid-drive kits are the most efficient???
Where did you get that from? I don't believe it's true at all, and I have two of them.
teslanv said:d8veh said:Kmob1 said:I believe mid-drive kits are the most efficient???
Getting 13 watts/mile with my BBS02. Pretty darn good, I think.
cal3thousand said:You mean 13 Wh per mile?
Is that recumbent or something?
What is the shunt resistance on your controller?
And how fast are you traveling to get that effiency.
triggeraa said:Ride it like you stole it!
Kmob1 said:... I want to build one on a dual suspension bike. I'd like to hear feedback on what people recommend...?
d8veh said:I have two similar bikes. They have the same battery and controller. One has a GNG gen 2 with a Nuvinci N360,and the other a Bafang CST. My friend is the same weight as me and same level of unfitness. We go out for fairly long moderately hilly rides more or less side by side on these two bikes. The hub motor normally uses less power by about 10%. Sometimes they're close, but the hub motor always wins.
13wH per mile means nothing. Sometimes I get 8wH per mile from my 500w Bafang CST, sometimes 25wH per mile. It simply depends on how motivated I am to pedal. Over about 1000 miles of commuting, my Cycle Analyst showed that I used about 13wh per mile on my 500w 36v BPM with 30 amp controller. That was with moderate pedalling.
It's difficult to beat the simplicity and reliability of a single rear hub-motor. I think that the recent motors from Bafang and Xofo have raised the game a bit for the crank-drives, but you've still got the problem of crashing gears when you have to change down going up steep hills unless you get a Nuvinci.
Bafang BBS02 Mid Drives: http://endless-sphere.com/forums/viewtopic.php?f=28&t=50104
LighteningRod's Kit: http://endless-sphere.com/forums/viewtopic.php?f=28&t=57720
These two kits are probably the best on the market right now, as far as aftermarket Mid-Drives..
d8veh said:I think that the recent motors from Bafang and Xofo have raised the game a bit for the crank-drives, but you've still got the problem of crashing gears when you have to change down going up steep hills unless you get a Nuvinci.
The motor can put a lot more tension on the chain than you can. It's therefore almost impossible to change gear with the power on. it's even worse when you use a PAS, because the motor runs on for a bit after you stop pedalling. If you get a crank-drive, you'll see what I mean. Imagine trying to change gear on a motorcycle without a clutch. It's OK on the flat, and down-hill, but when you're going up-hill with more power, it's a different story.Aushiker said:d8veh said:I think that the recent motors from Bafang and Xofo have raised the game a bit for the crank-drives, but you've still got the problem of crashing gears when you have to change down going up steep hills unless you get a Nuvinci.
I am curious about the "crashing gears" comment. Is this something of an issue with e-bikes (I guessing non-pedelec) because as a cyclist on a non e-bike this is is easily avoided by good riding technique, e.g., getting the gear right first; easing off a moment to change etc.
Andrew
d8veh said:The motor can put a lot more tension on the chain than you can. It's therefore almost impossible to change gear with the power on. it's even worse when you use a PAS, because the motor runs on for a bit after you stop pedalling. If you get a crank-drive, you'll see what I mean. Imagine trying to change gear on a motorcycle without a clutch. It's OK on the flat, and down-hill, but when you're going up-hill with more power, it's a different story.
[Re: Mid-Drive kits - where do I start?
by drew12345 » Mon Apr 14, 2014 3:55 pm
I really like the AFT mid drive but it's expensive. The AFT motor is a cyclone motor without the upgrades (oil, ceramic bearings, etc). So you can just get cyclone kit also for much cheaper.
However, Jim, at AFT, customer service is top notch! I haven't heard anyone have complaints with AFT who has one. It has a lot of cool upgrades like external oil reservoir.
It's my first mid drive so can't really compare to any others. It seems like a very solid setup and getting beat up on the trails and no signs of breaking down. Very happy with it!
With gng, you have a great support base here and cost is much cheaper.
The cyclone motors are somewhat noisy so keep that in mind. Mid drives also have a lot of moving parts and require more maintenance. /quote]
Thanks for the feedback. The AFT kit costs seem reasonable if the kits work reliably and there is good customer support. To me the most important thing is reliability as i will ride it to work and dont want breakdowns . Also don't have the time to repair and upgrade it like the gng kits need. Costs also seem a lot lower then the other high quality mid drive kits like the EGO or ECOSPEED...
