ElectroSurf3r
Hey yall,
This is my first solo ebike creation! I got a new scooter hub to test, dubbed "Mid Monster", and this thread will follow the build. The motor will be for sale on ES once we give it the green light.
I want to do a good bit of mods along the way, and I am trying to document my efforts, so we can all learn. Please chime in with any helpful knowledge!
So without further ado, Ladies and Gentlemen, the star of the show, and our test subject, Mid Monster!
Hello gorgeous wire bundle containing 6 phases! And shiny 10 inch scooter rim with tubeless valve!
WAIT. Why are some of the cover bolts missing?
OH NO
A quick glance over at the box that wasn't inspected in all the excitement:
GRRRRR
They just HAD to open it, and then didn't even close it back properly!
I do not like that!
Or that!
NOT COOL, DHL! :x
...So after moping around for awhile, I decided to go to Harbor Freight and get a giant 8 inch 3-jaw gear puller for $17.
We've got to diagnose the patient.
...and...
YES!!! the magnets appear to be fine! As do the laminations, halls, windings, etc.
The debris in the gap must have just been small chunks of the cover that got pried off.
DHL is still LAME, but this baby appears to be healthy! Now let's see what we got here...
56mm stator width, 163mm stator diameter.
Very fine laminations!
A quick check reveals approximately 29 laminations per cm, giving a total around 162 laminations over the 56mm width.
The windings appear to be 12 strands of 20ga magnet wire, so better than 10ga overall!
I see 20 magnets (10 poles), 24 stator teeth.
20mm Axle
14mm flats
194mm between flats
161mm cover to cover width
198mm cover outside diameter
6 phase wires, 10 pin hall connector, 2 pin temperature connector. 2 controllers to run this puppy!
Let's compare it visually with Mini-Monster HE 2-speed, which is on sale right now for a great price: http://endless-sphere.com/forums/viewtopic.php?f=31&t=40859
Key differences for Mid Monster: 3 hole disc brake mount, larger motor diameter and width, shorter axle, 6 phase, 1 speed.
Now I am trying to decide between:
1.) putting it back together, testing it stock, and continuing the bike build -or-
2.) embarking on ventilation & waterproofing mods this weekend.
The only controller options I have are 70A 18fet, and I have always run 20s, 74V nominal.
With 2 controllers drawing 70A battery side each, the first test ride will easily be surpassing 10 kW. It needs ventilation asap...
Looks like friday's shopping list includes drill bits, center punch, sheet aluminum, small bolts, epoxy, high-temp motor paint, and BEER.
OH NO
GRRRRR
I do not like that!
Or that!
NOT COOL, DHL! :x
...and...
20mm Axle
14mm flats
194mm between flats
