I had a similar idea except with 13 cell in each module :
https://endless-sphere.com/forums/viewtopic.php?f=14&t=57810&start=150
250 euros for 4 empty units (sold as starter kit)... So an empty 32 cell battery box for 250 euros.... Way to expensive
The springsteel contacts they use also seems like they will not be able to hande anything much more than an amp per cell...
The thing is, flimsy spring contacts creates resistance.
The added resistance generates lots of heat when the amp load is high.
Heat is the worst enemy of springsteel, as the tempered metal looses it's recoil past a certain temperature.
So the springs really need to be made of a beef wire gauge to withstand the amps without too much resistance.
Steel is also not as conductive as copper.
But copper does not have good recoil, and copper will form surface oxidation over time and create additionnal resistance.
I'm thinking they should invent springs with a springsteel core coated with an ultra thick copper-layer, plated with nickel for oxidation resistance...
