Hugh-Jassman
- Joined
- Jun 20, 2015
- Messages
- 407
I have been playing with the new motor simulator, but need to some incites to how to make it work best for this use of 450 lbs total combined weight on a 9%grade. [with a single reduction to the drive wheel as a mid-mounted single-speed drive] (belt or chain).
NO I DO NOT WANT TO USE IT AS A MID-DRIVE THROUGH THE DRIVE CHAIN.
I would really like to be able to drive 550lbs up these hills, but that is only possible with two motors, or at least much more power than I can bribe the cops to ignore. “Two motors” would more confusing to them.
According to this graph the stoke monkey (non-geared) will work at a very slow speed with a 2.16:1 ratio to the 26” wheel. Obviously I need more than 600 watts output, because even more reduction would make it too slow to balance.
What are the possible controller perameters?
What is the maximum power can any of the Stoke Monkeys putout?
It looks like the 7x9 and 8x8 are only 600w.
