torque and lever are two different things. i would never say that it's the same just to make people believe that they "understood" something. I like factual discussions.
Torque has the unit newton*meters, not ft/lb or ft/lbs that's simply wrong. lbs*ft would be ok for me, but lbs is a weight unit, not directly correlating with force well, as the gravity constant differs. Not what i think is a clean definition
kV is completely irrelevant for copper loss. It's always the same as long as you compare two same motors with the same fill factor.
Let say you use a 16:1 gear reduction on the smaller (100ft/lb) stator you will have 16x the torque - losses so < 1600 ft/lbs the smaller motor will have the potential to make less torque due to losses of the gear reduction. You can make both motors weigh the same and in that case they would have the same KW rating but the one with 16x the diameter of the stator will have lower losses and the total system will be lighter as it will have no gears for reduction.
what do you wanna tell me here? A four times smaller motor is more heavy than a big one?
Anyway, i posted facts here that are not so obvious. Took me quite some time to gain this knowledge i like share and discuss. There is quite a lot of half-knowledge out there (and here), which made me make false assumptions. For example that Km is a constant that is capable of comparing copper loss/ torque ability of different motors. But it's not. It's Km²
