safe said:eP said:It is unable to burn the motor in 3-5 seconds for the sake of heat. Cripled controller will stay much longer in that area.
You still don't understand....![]()
The "Motor Current Limited" bike is unable to produce heat in large amounts anywhere in it's powerband. The "Motor Current Limited" bike will never overheat... it's restricted from being able to do that.
It takes 2.59 seconds for the "Motor Current Limited" bike to get to 10 mph after which point things are always "ideal". The "Battery Current Limited" bike takes 1.84 seconds to get to 10 mph. The difference is only 0.75 second... that's "three quarters of a second" difference.
[/i]
It is at flat. Tell us Mr Teacher how many seconds your cripled "blind" controller need to catch up at speed the normal one ?
At higher gears the acceleration is lower and lower so it must take many seconds of extreme continuous heating to take back that 0.75 second losed at low rpms.
At what speed cripled one is able to catch up the normal one ?
safe said:
After that "three quarters of a second" things only improve and remain positive for the "Motor Current Limited" bike.
..."three quarters of a second"
How many seconds cripled one is late at 15% grade slope ?
How many seconds its need to reach the same speed which has normal one at the same moment ?
( It is the time until normal bike will be faster then cripled one )
ps.
Mr Teacher leave all bullshits for yourself. We need real calculations - we aren't as dumb as you want.
