safe said:eP said:Before you start the think which way is easiest, the better is start to calculate what we can gain after conversion and what we will lost.
We're moving on to the circuit design now.
Suffice to say that you now know that you have an "option". If you decide on using gears on your bike then you have the option of trying this controller design to optimize the benefits of gears.
Option for which motor ?
If you want upgraidnig this way very efficient motor yours gain will be relatively small and torque sacirfice relatively high.
Think about for 95-99% efficient motor for example.
If you want that circuit for relatively inefficient motor the gain will be higher but torque sacrifice still relatively high. So the better option at this case will be changeing the motor for more efficient one without any sacrifice.
So since now i will be completely silence.
Good luck.
