foiloco
I have an unusual application. It is a solar powered tricycle human following robot ( http://solarburro.net/home.html ) which has a limited speed range of about 2 to 4 miles per/hour. I want to use an available bike hub motor to drive this tricycle with a fixed belt reduction drive. I don't want to use a geared motor. I don't like the noise.
I found a hub motor that can be operated with 36 or 48 volts. The manufacture has supplied me with performance data tables.
The data tables show the motor performance at 36 and 48 volts for the motor. The data shows the maximum efficiency of the motor is at 248 rpm for 36 volts and 335 rpm for 48 volts.
Why does the maximum efficiency point increase linearly with applied voltage?
My application needs about 24 watts of power to drive it's wheel on level pavement and 250 watts to climb a paved 20 percent grade at 3 mph.
The smaller my belt reduction ratio the better. The motor will supply the power I need at 36 volt. So I will use a 36 volt battery.
I see that the motor maximum efficiency point increases linearly with voltage. I want to set up my belt reduction drive to operate at the maximum motor efficiency at 3.5 miles per hour with a power output of approximately 30 watts.
My understanding is that under normal operation the analog voltage sent to the motor controller from a throttle assembly is a commanded speed, The motor controller uses PWM to set the output power as required to achieve the commanded speed. So in my case the PWM duty cycle at 3.5 mph on level ground will be about 30/300 or 10 percent. So I am running the motor at the maximum efficiency speed from the performance curve but at a PWM duty cycle of 10 percent.
Argument 1: "My thinking is all wrong and too simple. The ten percent PWM duty cycle makes the voltage equivalent to a steady 3.6 volts. According to the two motor performance curves the motor maximum efficiency will be at 254 x .10 = 25.4 rpm. At 254 rpm the efficiency will be terrible. You've blown it again."
Argument 2: " No you've got it all wrong. When the PWM pulse is applied the motor is seeing 37.5 volts and it is operating at it's maximum efficiency speed so all is good. Between the pulses it's just coasting. there is no problem. You've done everything right. "
I guess that argument 2 is correct. My motor will operate efficiently. I want to hear from others and feel confident that I haven't blown it again. Is Argument 2 correct? If not what should I do? Thanks for your comments.
