- Joined
- Dec 19, 2021
- Messages
- 50
For my small mobility scooter...
Question: Would a larger motor increase speed/torque when going up hills (if I still use original 50A controller and 21AH AGM batteries)?
There is no available space to increase AGM battery size. I need to continue using lead AGM batteries. One reason is lead batteries (mounted in floor) are ballast to keep low enough center of gravity.
More Background Info:
I have a mobility scooter with a 330W motor (brushed motor) and 50A controller. It's a 24V system with two 12V deep cycle AGM batteries in series.
I increased tires diameter from 7.5" diam to 10.4" diameter (thus 38.7% higher gearing than stock).
I increased the onboard controller computer program max speed setting to 100%. This increased RPM (voltage) to max that controller and batteries can deliver.
Top speed increased from 4 to 6.5 MPH on level ground. I'm happy with speed on level ground. Real world range decreased from 6 to 5 miles. I'm satisfied with range.
However, it now bogs down when going up hills. It needs slightly more torque for hill climbing.
It currently has a 330W (brushed) motor. There's a 420W (brushed) upgrade motor available that would easily bolt-in.
There is insufficient space to increase batteries size. I need to continue using lead AGM batteries.
