safe said:Everything makes sense except the 100% duty cycle part.
<snip>
Look at a typical 36 Volt 750 Watt Unite Motor performance chart... (it's possible that the numbers don't fit right, but the idea is sound... if you understand his train of thought :? )
Power(In), Power(Out) and Heat are in Watts times the scale.
(and a final note, if you overvolt the motor it changes everything, so the only way to get to 2500 Watts for peak power is to overvolt, which means all the charts need to be modified to view that)
In which way you are going to dissipate heat generated by 50A current if the motor is rated for little over 20A for the sake of low ability to heat dissipation ?
In other way its nominal power out will be much higher than rated 750W what we can see at your chart.
I see you are going to burn next one.
