Noamsal said:
i just wrecked my back wheel today, and want to upgrade to a motorcycle rim, but i don't want to change the overall diameter of the wheel (26" bicycle wheel). i ride off-road with a downhill bike and have a bafang geared 500w motor, and i want to have a rim and tyre in motocross style, any recomandations?
Motorcycle rims are pig-heavy and much weaker for their weight than bicycle stuff. They are set up for really thick spokes that don't give you any advantage in the e-bike application, but are much heavier and a nuisance to lace and service.
If you can even fit a moto rim in your bike, consider
one of these instead. It's a double-walled, 65mm wide, roughly 1100 gram rim that amounts to twice as much beef as a typical freeride rim. But it is designed to work with normal bicycle spokes and tires, which are are much better than moto parts for any e-bike under about 5hp. And even a 3"+ MTB tire weighs a fraction as much and has a much lower rolling resistance than a moto tire the same size.
You'll be squandering the limited power of your 500W motor by using motorcycle rims and tires designed for at least twenty times as much power. If what you want is a motorcycle, just get a motorcycle (and try not to hurt yourself).
