John in CR
100 TW
Safe,
Even if I lend you a couple of clues you'd still be clueless, so why bother?
John
John
The idea of rotation about the rear contact patch is clearly false based on what we know about countersteer.
"Lean" gives reference only to a horizontal plane (i.e. the horizon)
"roll" gives reference to what the bike's mass is actually doing when it appears to be leaning.
SteveMush said:Why is it that the blind and the desperate inevitably ..........
Read the excellent articles at:
http://en.wikipedia.org/wiki/Bicycle_an ... e_dynamics
http://www.dclxvi.org/chunk/tech/trail/
EXCELLENT explanations of factors affecting bike stability and control.
SteveMush said:That bike dynamics and behavior are continuing topics of discussion is pretty good proof that there are many theories ...
safe said:All I'm saying is that there is a single idea that has been presented here that is clearly wrong and it's the idea of pivoting on the rear wheel contact patch as the roll axis. I'm not trying to answer all things to all people, but just to correct that one mistake.
safe said:People that mount their batteries on the back or down really low are doing it wrong.
safe said:Mountain bikes definitely need the weight up because you start off so high up to begin with.
safe said:On a "well behaved" bike the body and the bike should rotate about the SAME axis... just remember that... when you separate your body from the bike it makes everything worse. Don't place the CG of the bike anywhere that is distant from the CG of your body.
John in CR said:Safe,
You can't even get "conventional wisdom" right. ...... *** **** edit by ypedal ****.
Have a nice day,
John
Tiberius said:John in CR said:...on the point you and safe have discussed the most here, he is right and you are wrong.
Nick
John,John in CR said:Tiberius said:John in CR said:...on the point you and safe have discussed the most here, he is right and you are wrong.
Nick
Oh really? Please do explain. While you're thinking about how to do so, think about this. Imagine 2 infinitely small 500lb weights and two identical bikes. Place one weight at the unladen CoG of one bike and one weight at the rear contact patch of the other bike. Neither weight changes the CoG of either bike as long as both wheels remain on the ground. Let's ignore the impact on traction, tire deformations and the fact that during turns the contact surface moves away from the centerline, because these are all irrelevant to the point of disagreement.
I maintain that one will feel heavy and steer like a motorcycle with the difference in handling quite noticeable, and the other will lean, steer, and countersteer exactly as it did before adding the weight (identical angles and feel). There will be a small effect resulting from countersteer moving the contact patch weight a slightly greater lateral distance, however, the angles are so small that even at 500lbs the difference is negligible. Note that I'm not saying you won't feel that you're dragging around an extra 500lbs, just that it won't really change the way the bike turns.
Note that I also never said handling like a motorcycle is necessarily bad. The point I've tried to make is that as you move away from the rear contact patch, the weight of batteries will have more effect on handling. Others have already described the effects depending upon the location, but only a few have agreed which direction minimizes those effects. The rear contact patch is just a starting point, because it's the anchor point of all movement in the frame, and there are other considerations to take into account in determining battery placement including convenience, which I consider to be more important than all other factors. By convenience I mean not getting in the way and not making it cumbersome when off the bike, but Safe would never consider using that to explain why those expensive bikes put their batteries in the center, since no one would disagree.
Edit: Please note that knocking sense into youknowwho was meant only in a joking and figurative way, not literal. For someone to take offense is either misunderstanding or typical oversensitivity toward political correctness that has become problematic in today's society. I don't believe my post warranted modification, though I would have done so myself if asked. Rude and crude, sure, but only in jest, and still far less obnoxious than the repeated posting of irrelevant large pics and graphics.
John
So we have two weight locations. (I just want to be sure we are in agreement) One is in the center, what I can the "conventional wisdom" location. The second is in the rear contact patch location.John in CR said:Imagine 2 infinitely small 500lb weights and two identical bikes. Place one weight at the unladen CoG of one bike and one weight at the rear contact patch of the other bike. Neither weight changes the CoG of either bike as long as both wheels remain on the ground.
I think I can identify your mistake here. (and others feel free to comment about just list limited issue and don't sidetrack things please)John in CR said:There will be a small effect resulting from countersteer moving the contact patch weight a slightly greater lateral distance, however, the angles are so small that even at 500lbs the difference is negligible. Note that I'm not saying you won't feel that you're dragging around an extra 500lbs, just that it won't really change the way the bike turns.
safe said:I've been stubburn and wrong before too. It might be a simple matter of getting John to see why what he thinks does not apply in all cases. He does have a point at extremely slow speeds. Many of these little scooter things are perfectly capable of doing their job at speeds below 10-15 mph.[/color]
