You mean iron losses?Thud said:The coging losses are at the top end of the rpm range where they wont be in play for us most of the time.
I vote for a twin rotor with back-to-back rhomboid/mandorla shaped coiled strip cores & windings.Thud said:I am still of the opinion cores are to our benifit at this scale.
Why not flip the stator plates to the basket?liveforphysics said:Gotta come up with something better thenMiles said:Sure, you can cantilever it from one side. I still don't like like it....![]()
Get to CADoodling![]()
TylerDurden said:Why not flip the stator plates to the basket?liveforphysics said:Gotta come up with something better thenMiles said:Sure, you can cantilever it from one side. I still don't like like it....![]()
Miles said:Then we're back to some kind of yoke cores, or a less than optimal magnetic circuit..........
I'll make the twin rotor compromise.....
Miles said:If you use a halbach array for the twin rotors then, potentially, you get a better magnetic circuit than you can (without difficulty) get with twin stators. No?
Thud said:![]()
a rotor assembly built on a cast hub, laser cut iron flux ring,turned to inset magnets & bond them.
open center section will provide opportunity for active airflow cooling.
Input please............
The same argument could have been made in the 1980s, when Cedric Lynch was developing his designpaultrafalgar said:The very last thing I want to do is dampen anyone's enthusiasm for speculation/experimentation, but I'm thinking: The design of electric motors has gone on for at least a 100 years with a huge financial incentive to making the best design. Is it not likely that the adoption of a current design would be more profitable to us than reinventing the wheel?
This is a phrase that raises my defence every time I hear the "but"paul trafalger wrote:
There is a LOT of design talk happening here that is going way beyond my education & I enjoy that.The design of electric motors has gone on for at least a 100 years with a huge financial incentive to making the best design. Is it not likely that the adoption of a current design would be more profitable to us than reinventing the wheel?
I think thats a fine idea, please do & best wishes.so what about asking Cedric (he's a very "alternative" thinker) to produce a motor downscaled for ebike use? What do you think?
As Kv goes down inversely with field strength and it can be adjusted by the number of turns in the winding, I don't see that this is a great sacrifice.Thud said:Are we willing to sacfrice pole count (raising Kv)
Well, the LEM 130 isn't as impressive as the larger models - I'm not sure I have an explanation, though....paultrafalgar said:OK, Miles, but I'd still like you to explain why/if that design could not be used in a lower power form. Anybody?
paultrafalgar said:The very last thing I want to do is dampen anyone's enthusiasm for speculation/experimentation, but I'm thinking: The design of electric motors has gone on for at least a 100 years with a huge financial incentive to making the best design. Is it not likely that the adoption of a current design would be more profitable to us than reinventing the wheel? I suspect that a lot of the best designs are for higher power motors, so thinking in terms of downsizing an existing design might be the way to go. In that vein, can someone explain to me why an Agni motor couldn't be downsized to give less power? There is the problem of patents, of course, and so what about asking Cedric (he's a very "alternative" thinker) to produce a motor downscaled for ebike use? What do you think?
