Samd
I suspect more people read this forum in China than we give credit...
Willow said:The drawing shows the wiring exiting the through the rubber cap at the end of the axle - this is not correct... the wiring exits from the flat side of the axle - just like the crystalytes. Drawing may have been done for a hollow axle setup.
Have you changed the amount of copper inside? I can't find now but I've seen somewhere it is now 16x4t, not 15x4t. Is this correct?e4bike.ru said:Yes, v2 prototype received.
stepan said:
e4bike.ru said:We have clients who use usual aluminum frames and no such problem ever happened. We always warn of using good torque arms that can prevent the axle of moving. Otherwise this motor will break the dropout before scratching it. Such modification will increase the weight. Also new bearings should be used. And the covers should be modified. This will definitely increase the price. I really don't think that such problem can occur if good torque arm is used.
13AWG phase wires are used in v2. The phase current in the hills video was set to 180A for the first part and then set to 220A. I never had any problems with such wires with 4T motor. The PP30-45A Andersons will melt first but no problems with them either. The 3T version will have problems with 13AWG phase wires, that is why we don't offer it.
e4bike.ru said:
Outside is the same as v1. What else would you like to see?![]()
I agree this would fix 2 of the biggest problems for hot rodders,# 1 axle breakage/ twisting and # 2 phase wires melting... having a big enough channel to upgrade to 10 awg phase wires would be a dream come true, what is the axle steel grade.stepan said:@e4bike.ru If you only could make the flat axle diameter 20mm or more it would solve those 2 problems easily. How you think of this change?
That would be great!e4bike.ru said:I will talk with MXUS about such axle and cover mod. This can take some time. We are preparing a new controller now and it takes much time also.
Allex said:So cromotor mini 10kg and big brother is 11kg.
Almost no difference. :9 Might as well get the big one =)
e4bike.ru said:Since the lamination are the same width as original v2-v3 Cromotor such RPM should be similar. I can try to measure such loses if you can give me some instructions just to be sure the results corresponds.
Willow said:Allex said:So cromotor mini 10kg and big brother is 11kg.
yep.
