wesnewell
M14 x 1.5mm thread, not 2mm.
Emmett said:A smaller wheel is not an option for me. I don't want to upgrade my controller or battery while they under warranty and I've got time and budget limits too.
chucho said:What do you guys recomend me for this motor in a 20" bicycle rim... 0 or 1 cross? 11g, 12g or 13g?
teklektik said:An observation by Justin re: radial lacing vs paired spokes...
I haven't done this myself, but it looks like you do the same thing as with radial (0-cross) but check the 'paired' box and add the pairing info to the field.chucho said:
I'm not a wheelbuilder, but based on Justin's remarks I'd start reducing the default 'even spacing' value until the spacing yielded an angle in the zone Justin recommended. Others more skilled at this may offer better suggestions.justin_le said:I'd aim for more like 80 degrees, especially if the spokes are short. Typical bike wheels are like 82-83.
teklektik said:I haven't done this myself, but it looks like you do the same thing as with radial (0-cross) but check the 'paired' box and add the pairing info to the field.chucho said:...no clue how to calculate spoke length.. Need some help :|
This is the way i did it with radial
(I finagled your illustration above)
With the box unchecked, the 'Paired Hole Spacing' in the greyed out field seems to display the computed 'evenly spaced' hole distance based on Hub Flange Diameter and Number of Spokes.
John in CR said:Teslanv,
You worded the poll as if the myth regarding torque wound motors was true. Kiwifiat and Kingfish got their legs cut out from under them by the real experts, so the myth is toast. Even Madin88 has come around though he prefers to save some weight in copper outside the motor, There's no difference in torque the torque they can make, and different winds make the same heat for the same torque. A high turn count motor doesn't make you able to run a bigger wheel, or climb a mountain any better.
I'm sure you want no part in selling something based on misleading information, it behooves you to gain a good understanding of this, and then you can make educated ordering decisions and give customers good advice. Because controller voltage limitations are real, there's an opportunity for a real competitive advantage by offering a 3T for those who want to maximize power. Until you step up to the much heavier highest power hubmotors for big scooters, higher Kv motors aren't generally available, so there is a gap in the market waiting to be filled.
Yea, I'd defer to Justin's judgement with respect to all things wheelbuilding around a hub. For smaller wheels - 20 to 24", I'd also aim for that, a 0-cross radial, and use a 12 or 13 gauge spoke, perhaps 10 or 11, but would defer to JRH and would get the spokes, or a full build from him.chucho & teklektik said:I haven't done this myself, but it looks like you do the same thing as with radial (0-cross) but check the 'paired' box and add the pairing info to the field. With the box unchecked, the 'Paired Hole Spacing' in the greyed out field seems to display the computed 'evenly spaced' hole distance based on Hub Flange Diameter and Number of Spokes.
Most everyone will have one, maybe two eBike builds and will be in no position to judge the veracity of any particular thesis regarding "speed" and "torque". The general recommendation here on ES should be to pick one of the better vendors, like GrinTech or EM3ev, tell 'em what you want in the way of the price, speed, battery, weight, distance trade-offs, and trust their recommendation, leaving the "speed versus torque" question out. The MXUS group buy is for a more advanced crowd and hopefully, there aren't any newbies in the buy.teslanv said:John in CR said:Teslanv..... Because controller voltage limitations are real, there's an opportunity for a real competitive advantage by offering a 3T for those who want to maximize power. Until you step up to the much heavier highest power hubmotors for big scooters, higher Kv motors aren't generally available, so there is a gap in the market waiting to be filled.
Regardless of whether the "Myth" is true or not, the majority of ebike builders still refer to the different windings as "High Speed" and "High Torque". I'm just sticking to socially accepted norms.
teslanv said:John in CR said:Teslanv,
In my opinion, calling them anything else just confuses people even more.
For the record, I understand better now how much a smaller diameter wheel/tire affects the performance of "High-Speed" Motors. Obvious efficiency gains can be made by choosing the smallest acceptable diameter tire in any winding of motor.
Allex said:So can you explain for the usual mortal people in here why Hub motors exists in different windings? Is it because manufacturers do not understand and driven by the Myth?
chucho said:Allex said:So can you explain for the usual mortal people in here why Hub motors exists in different windings? Is it because manufacturers do not understand and driven by the Myth?
I think... it is for having diferent speed for same voltage![]()
999zip999 said:For what reason would you like a 5t over a 4t ?
