John in CR
100 TW
kiwifiat said:John in CR said:Teslanv,
You worded the poll as if the myth regarding torque wound motors was true. Kiwifiat and Kingfish got their legs cut out from under them by the real experts, so the myth is toast. Even Madin88 has come around though he prefers to save some weight in copper outside the motor, There's no difference in torque the torque they can make, and different winds make the same heat for the same torque. A high turn count motor doesn't make you able to run a bigger wheel, or climb a mountain any better.
Not true John, the matter is still under intelligent debate in kingfish's tread. It seems that you place an incredible amount of faith in the opinion of Liveforphysics, good for you.
As a scientist I need proof and I haven't seen it yet, but will be happy to be proven wrong. That proof will need to be a bit more rigorous than "liveforphysics said so".
There's no debate in Kingfish's thread. You and he were both on the wrong side from the start, because neither of you considered the change in resistance. We gave you simple examples where the math proves it quite simply and with certainty.
Here's a March 2011 quote from Justin, our forum host and maybe the smartest guy in the world when it comes to ebikes,
If the myth continues that the slower speed motor winding leads to a higher torque motor, then ARRG I will want to roll in a grave.
