MAGICPIE3FOCUSPOWER
For 20S (75V) 4T is the best choice right? looking....at speed:torque ratio?
MAGICPIE3FOCUSPOWER said:For 20S (75V) 4T is the best choice right? looking....at speed:torque ratio?
For any winding, the smaller the wheel the better, if it suits your target speed. For me, that is a 3T winding, 17" Moto rim with a 21.5" O.D. tire and 120+ phase amps. With a 20S battery, my target speed is 50 MPH. If I can't get 50 MPH with 20S, I have a 4115 controller that can take 150V max.![]()
chucho said:MAGICPIE3FOCUSPOWER said:For 20S (75V) 4T is the best choice right? looking....at speed:torque ratio?
What rear wheel are you gonna use?
And amps?
For 1 second ? :wink:MAGICPIE3FOCUSPOWER said:max. 350A phase controller.
The MXUS 45mm motor is rated for 6Kw Peak. Even at just 48V, 350 Phase amps is 16.8Kw.MAGICPIE3FOCUSPOWER said:Haha I think you are right:lol:
Isnt the controller bucking the voltage down on low RPM ?teslanv said:The MXUS 45mm motor is rated for 6Kw Peak. Even at just 48V, 350 Phase amps is 16.8Kw.MAGICPIE3FOCUSPOWER said:Haha I think you are right:lol:
You may want to beef up those phase wires a bit. :wink:
90 Phase Amps should be fine, as long as you are not running it WOT for extended periods.MAGICPIE3FOCUSPOWER said:Thank you!![]()
I have a question about your graph at right of the graph I see phase currents.
90A is still safe right?
\/ampa said:Isnt the controller bucking the voltage down on low RPM ?teslanv said:The MXUS 45mm motor is rated for 6Kw Peak. Even at just 48V, 350 Phase amps is 16.8Kw.MAGICPIE3FOCUSPOWER said:Haha I think you are right:lol:
You can take the approach of Paul at EM3ev - I've got one of his laced MACs. Which is to lace the spokes with the head all pointing in the same direction. What I'll be doing when I get around to it.markz said:About to lace up my motor, is EVERYONE dishing their wheels? Seems like a major learning curve to dish the wheel.
I got a regular 19" mountain bike, Specialized Rockhopper.
louis raaijmakers said:hello es
i got a mxus in a 26 inch wheel from the factory.
but i hit a curbe hard and now my rim is a bit f##ked up.![]()
i was thinking of going to 19 ich motor wheel but does any one know how to do this?
or has anyone already done it?
then i would like to know the length of the spokes
greetings louis
teslanv said:Phase resistance for the MXUS XF40-45H V2 (Al Stator) 21X3T Winding (Stock Phase Wires):
0.216V Voltage drop with 3.04A current.
.216/3.04=0.071 Ohms Resistance.
At 120A Phase Current, that will generate (120^2x.071) = 1022 Watts of Loss
KV tested at 565.7 RPM at 48.1V, so 11.76 KV.
2.0A current at No Load.
That's right inline with the Fast Wind Crown...
http://www.ebikes.ca/shop/ebike-parts/motors/mtc100r24.html
Gofundme only accepts credit cards through WePay and Stripe, it looks like. However if you want to make a direct donation to the project you can send it via PayPal to my email address. barenthoffman@outlook.commadin88 said:teslanv said:teslanv, i would like to donate via paypal, but it looks like gofund only supports credit card. could you offer paypal as option?
