I hadn't been following this thread, so just spent a good 4+ hours skipping through it trying to catch up.
It was good to learn all about the difference between motor winding/turn counts and how the myth of lower turns equaling more torque is false. That info should be put up in a separate thread for more people to find IMO.
The main reason I'm interested in the MXUS is because I
stripped the axle on my HS4080, which I've recently spent
many hours modifying for increased cooling. I'm sick of the ongoing issues I've (and I see others from reading this thread) had with my Crystalyte motors. This is the 4th Crystalyte (2X HS35xx and 2X HS40xx) motor I'm on now and every one of them has had axle issues mainly caused IMO from the small 1/2" axle size.
I'm going to try and get the axle repaired (reduced to 12mm) first before buying a MXUS, but if that fails (which it likely will eventually) the MXUS is the most logical choice for my Fighter.
Anyway, I have few questions I wasn't able to see the answers to...apologies if I skipped over the answers.
1) Is there a V3 of the MXUS coming (already out?)? What are the differences?
2) I plan on using it with my Mini-E (65A) on 12S (45V) LiPo in a 24" rim. From what I can tell the 3T would be best, but I don't need much top speed. Would the better copper fill of the 4T be better for overall higher efficiency given the Adaptto's ability to generate speed with OVS when (occasionally) required and the increased time spent in a higher efficiency zone when at or near 100% PWM?
3) I already have a rim + spokes from a dead HS4065 motor. I notice the diameter of the HS40 spoke flange is only 0.2mm larger than the MXUS, and the inner flange width is 0.5mm bigger on the MXUS.
http://www.crystalyte.com/Dimensions_H40 Series.pdf
Does anyone think I would work for me to reuse the spokes/rim from the HS40 to lace the MXUS?
Alternatively, is the magnet size and pole count for the HS40 and MXUS the same? The dimensions are so close, it looks like I could just drop the MXUS stator into the HS40 magnet ring...or is that a bad idea?
Thanks in advance to anyone who responds.
Cheers
