madin88 said:you have forgot to half battery and controller Ohms on the 3t setup. thats at least one reason that 6T is faster (less voltage sag)
i always set these values to zero
teslanv said:Conclusion: While a 3T MXUS may be able to run fine in a 28" (Fat) Tire without overheating, it is NOT as efficient as a 6T with twice the voltage and 1/2 the current.
teslanv said:Here are two different simulations of the MXUS 45mm Motors:
The first simulation is a MXUS 4504 (3T or 12Kv) winding in a 28" Tire, with a 36V battery and an 80A Controller.
The second simulation is a MXUS 4506 (6T or 6Kv) winding in the same 28" tire, but with twice the voltage and 1/2 the current.
All other parameters are identical.
In therory, the Myth says that these should be identical performing systems.
You will notice that the 6T winding has a higher max speed than the 3T, so if I reduce the throttle down to 91% on the 6T to match the max speed of the 3T set-up, I get the following:
And here are both 3T and 6T windings overlaid:
3Tx20 has same copper fill as 6Tx10 - only losses between connections inside the motor are a tiny bit higher.Rix said:Thanks for posting TeslaNV, Justin's simulator also tell me that most likely total copper fill on the 6T has got to be at least a little more than on the 3T which is why the NM Torque data isn't closer then that.
madin88 said:3Tx20 has same copper fill as 6Tx10 - only losses between connections inside the motor are a tiny bit higher.Rix said:Thanks for posting TeslaNV, Justin's simulator also tell me that most likely total copper fill on the 6T has got to be at least a little more than on the 3T which is why the NM Torque data isn't closer then that.
IMO the real reason for its lower efficiency is that in the simulation phase wire losses are included in total efficiency. thats the reason why 3T has less top end -> because of its higher amp need, the voltage drop from controller to motor is much higher and therefore torque also is lower
Yes, in theory, for truly equal performance between systems, you would need to reduce the system resistance in half. Easy to do with the simulator, by selecting 1/2 the values. Much less easy to do in practice. It requires double the ampacity of the battery and phase wires and connections, as well as all the components in the controller's power stage. This is all glossed over in the theory of the myth discussion, but it is a reality that we must accommodate for when configuring complete systems with off-the-shelf and non-modified components.madin88 said:you have forgot to half battery and controller Ohms on the 3t setup. thats at least one reason that 6T is faster (less voltage sag)
John in CR said:In practice the speed wind wins, because you don't end up going to double the phase amps and begin to appreciate the attraction of smooth starts without doing so by artificial means that end up coming back to kill on hills. I've been using speed wind 40mm stator motors since 2008, and I live in a mountainous country and push a much higher than typical load before considering I often carry a passenger. None of those have temp sensors, and most are still sealed, and all have been bogged down on grades too steep, yet I've never burned one up. Those are set up for a top speed right around 60mph whether it's with a moto wheel with a 20" OD or 24" OD. While that's still just anecdotal evidence it trumps anything the slow wind camp can counter with, simply because it's in direct opposition to the myth.
As far as the sims go, with Justin proving through sims that the motors are identical regardless of winding why go any further? Without understanding I'll always just take Justin, Miles, LiveForPhysics, etc. word for it without question. Then I'll go back and figure out why they are correct. LFP has opted in favor of speed wind motors to reduce BMS costs, and he looks at controllers as simply buck convertors so pack voltage doesn't even matter. I opt for them because controller voltage limitations make the speed winds capable of more power. Justin and Miles look at motors from the standpoint of electric assist, so to them the motors are identical and using what is convenient in terms of equipment you already possess or staying with the common 36V/48V options.
John in CR said:Without understanding I'll always just take Justin, Miles, LiveForPhysics, etc. word for it without question.
teslanv said:markz said:OK I've been playing around with the simulator, 3T compared to 6T.
I see how the torque line can match, upping the controller amps and changing the diameter of the wheel. That makes a lot of sense now.
However I have a fixed controller, and a fixed motor (fixed = factors you cant change), and the only factors I can change are the battery and wheel. Which is my case.
The battery I can have increased voltage to increase speed. Increase amps to increase torque, I guess that would be on the phase, and changed in the controller. Is anyone putting 242A to the phase? Can the Lyen 18fet handle 242A on the phase for 60seconds?
The wheel size difference does not show up on the graph in terms of torque, but the speed changes I see.
Efficiency seems to be 6% difference, until 28km/h when it reaches 10% diff. The higher eff is 6T.
This efficiency leads me to think the 6T is better then the 3T, but the above quote prooves me wrong.
What size tire would you prefer and what top speed are you shooting for?
A Smaller wheel will result in greater acceleration and climbing ability, but a larger wheel will generally provide for a better ride experience. A higher Kv motor (3T) will be more efficient in a small diameter tire and faster overall, while a 6T motor can handle larger tires like a fat bike tire much better without overheating, and provide greater overall torque and require less current to do so.
macribs said:@Rix I might be 2 drunk to understand this, but I always thought John in CR was a high voltage man? I've seen several posts where he runs way more then 100v. Does he have a new build that is running 48v? Oh well 1 in the morning and my glass i almost empty. Time for bed, I will check thread tomorrow with a heavy head and fools remorse
Cherioo all you bastards!![]()
Samd said:I have to admit its what initially attracted me to the mxus. The thought of inexpensive controllers running on lower voltages, and a couple of commoditised 48v batteries in parallel to handle the ampacity. Cheaper system overall.
Was surprised then when people started mating them up with dearer components such as the Max-e , although I totally get that its for a high end build in that case.
Rix said:John, just curious, but are you getting 60MPH out of a 48v set up? I am not being a smart a$$, I sincerely want to know what you got going on that's the case. I am getting ready to start another build soon. I will be running the MAXE on 16S with the MXUS 4T and I am figuring with OVS max @ 7, I should break 50MPH. Even though everyone is free to run as many volts as their hearts desire, I agree with you about motors with lower turns and less volts.
madin88 said:Rix said:John, just curious, but are you getting 60MPH out of a 48v set up? I am not being a smart a$$, I sincerely want to know what you got going on that's the case. I am getting ready to start another build soon. I will be running the MAXE on 16S with the MXUS 4T and I am figuring with OVS max @ 7, I should break 50MPH. Even though everyone is free to run as many volts as their hearts desire, I agree with you about motors with lower turns and less volts.
Instead of using OVS7 to achieve the top end you like to have, it would be better to take the 3T motor.
Or go with 20s instead of 16 and use lower OVS level. This would be MUCH more efficient.
btw: the coming days i will assemble my heavily modded 3T motor. the mods in detail:
- custom axle (will offer them also for sale)
- 8mm² phase wires
- shilded extra cable for halls
- entire inside painted black (justin has proven that this would improve cooling / heat absorption by approx 20%)
- aluminum heat sinks attached to the inner side of covers to increase surface area
- 2 blower wheels from pc fan also attached to the sidecovers for good air convection
the goal:
i want to have a motor with same (or more) continuous power than the Cromotor, but with the benefit of 3-4kg less unsprung weight for a more comfortable riding and for less physical effort if i need to carry the bike upstairs into my flat
teslanv said:John in CR said:Without understanding I'll always just take Justin, Miles, LiveForPhysics, etc. word for it without question.
Justin, Miles and LFP are smart guys, no argument there. But I don't take everything they say as gospel. Only as a starting point to extend my understanding.
teslanv said:John, you generally run a smaller diameter tire with those high speed winds, if I'm not mistaken.
teslanv said:OTOH, with respect to slower speed bikes (under 35 mph) where larger tires are desired (such as a Fat Bike), a slow wind (high Kt) motor makes sense because the controller can be of lower spec and low cost, even voltage up to 18S are reasonably safe and the BMS (if present) is not as complex or as costly as you suggest.
John in CR said:Comparing the phase-to-phase resistance for the 3T and 6T, I may have found the reason for differences showing up in the simulator. You should remeasure to be sure those figures are accurate, because if they are then the 3T doesn't have near the copper fill it should. The 6T should have a bit over 4 times the resistance, because it's double the length and 10 strands vs 21 strands. It could be that the copper is there, but not all 21 strands are electrically joined. I don't know how the factories do that part but I've had trouble getting all the strands well connected at both ends when using magnet wire to maximise copper through the axle. Unless I'm missing something there are only 3 possible explanations for 220mOhms for the 6x10 and 70mOhms for the 3x21:
1. Measurement error
2. 21 are there but some aren't connected
3. Not all 21 strands are there
macribs said:@Rix I might be 2 drunk to understand this, but I always thought John in CR was a high voltage man? I've seen several posts where he runs way more then 100v. Does he have a new build that is running 48v? Oh well 1 in the morning and my glass i almost empty. Time for bed, I will check thread tomorrow with a heavy head and fools remorse...
litespeed said:Well for the second time it appears I lost my halls in my 6T. I was doing some full throttle runs and pulling my son up our slight hill on his skate board. Did it easily with me, the bike and him. 205 lbs me, 120 lbs bike and 165 lbs him. Temp on the outside never exceeded 120 degrees but not sure what that translates to on the inside. I'm ordering fans, 10 more genuine Honeywell SS41 halls and cutting holes for forced cooling CowardlyDuck style. Amps max at 70 and phase is turned down to 100 so I'm not really pushing it that hard...or so I believe anyway.
Not sure what is up with the halls sensors though. Spec sheet says good to 150 Celsius, surly there is no way I reached that with a 120 degrees or 49 degrees Celsius on the outside covers? Anyway I pulled the hub apart so I could measure to see what size fans I can fit in there. Looks like 6--25mm square fans.
I think I just need to order the QS205 or QS273 motor and deal with the larger mass.
Tom
