madin88 said:
- if you do not want to go fast (as ex fat bike) than a slower motor will offer more system efficiency -> right
Wrong, as is the now often repeated "slow winds are better for big wheels", and every other different wording of the same tired myth. Yes, as I've said many times controller limitations at both ends of the spectrum can make slow winds more convenient for slow and low power, and fast winds more convenient for fast and high power, but everywhere in between they're effectively the same motor. It took me quite a while to fully let go of all facets of the myth despite equivalence of the motors staring
Of course if someone is running high current at a minimum they should upgrade the wires starting just outside the motor, and I have little doubt that some type of wire upgrade is commonly suggested to Teslanv's customers.
If controller cost is what you want to hang your hat on, then I'd counter with the fact that more controller can be had for less.
If you want to talk about overall system efficiency, then of course everything needs to be properly sized for parity, but controller tuning is of far greater importance for efficiency, since the vast majority of losses are in the motor. The slow cruising types should try a fast wind motor at less current than the turn count ratio would dictate. Use a higher voltage than the ratio warrants, but limit the top speed in the controller. The result will be greater overall efficiency, smoother take offs with better acceleration through the mid-range to top speed. I've lived with 2 turn motors with 40mm stators of the same basic design for almost 7 years, so I know how to get any result desired within the motor's capabilities. I still have all 5 motors in different implementations alive and well, 2 in small wheels and 3 in larger wheels than I'd prefer. I have some slow wind motors too, so I know first hand that there's nothing a slow wind motor can do that a same model fast wind motor can't do as well or better.
On the subject of inductance, I finally tracked down my inductance meter, and my 2 turn motors have a phase to phase inductance of 90uH. I've only had controller heat issues with Infineon board controllers driving these and other low inductance motors. Considering the extra turn, mutual inductance, and the wider stator, I'd expect the 3T's inductance to be close to double, which should put it in a safe range... maybe not running 24s with a 100V component controller, but I always discourage that anyway.
If the extra 2m and 20 strands instead of 21 were included in the measurement to get to 70mOhms for the 3T, then that accounts for enough of the resistance difference that the WYE and phase terminations probably didn't miss any strands. I would like to know how they make the magnet wire terminations, because I didn't see that step in the video of Justin's visit to 9C, and I'd like to be able to reliably join bundles of magnet wire. How do they strip the varnish coating, and how to they soak the bundle with solder?
