markz
100 TW
Any news?
markz said:Any news?
teslanv said:A few of us have some samples incoming, but MXUS just told us the order was delayed due to "Paint" issues...
I guess they want them to look pretty since they know we are going to plaster tons of revealing images of them on this thread. :wink:
Rix said:teslanv said:A few of us have some samples incoming, but MXUS just told us the order was delayed due to "Paint" issues...
In a weird shitometer sort of way, that makes sense.
Soon there will be Shit hawks and samsquanches
macribs said:Meanwhile in China; QS 205 55H. Magnet Height: 55mm, 16 pole pairs.
QS 205 55H: Max torque 184 N.m. Rated for 4000 Watt
QS 205 50H: Max torque 168 N.m. Rated for 3000 watt
Anyone tested QS 205 55H? A 10% increase in torque and even 30% higher rating for power. I wonder what to expect from that motor compared to the 205 50H? Acceleration, speed and heat wise.
Thinking this might be a good fit for the new Vector mid drive frame. Loose the rim, either get custom cover with sprocket or modify existing sider cover to take a sprocket.
Meanwhile somewhere in China;
QS 205 55H. Magnet Height: 55mm, price 273 $.205 55H got 60% more torque then Mxus 5K.
Mxus 5k 55H:Max torque 110 N.m. Rated 4000 watt.
ridethelightning said:phase wire size of 50H/55 H are at least in the power ballpark for what these will be capable of running, not spec, but peak requirements of end user 8)
the mexus 3k phases are a joke, and no room for upgrade either- biggest deal breaker. i suspect the 5k will be a similar story.
macribs said:Click the image below for the full pdf of the motor drawing.
It says 99.5mm from very side of side cover to next sidecover. If you check with vito I am pretty sure they can press fit standard 205 50H axle into the motor. If they can should be no problem at all. If not you might need to do some axle or drop in mods.
Notice the 205 55H got equal power rating as the mxus 5J, but twice the size phase wires as the Mxus 5K, and 205 55H also got 60 % more torque then the mxus 5K. Got two more kilos of weight too.
From what I can see of the performance curve the efficiency of the motor is 90.7% @72v80A with 5.3 kw. I wonder what the numbers would be with 350 A or even 550 A peak current? Here is the performance chart. http://www.cnqsmotor.com/upfile/205_Motor_Performance_Curve/10_205_55H_V3_72V_1321RPM.pdf
macribs said:Meanwhile somewhere in China;
if the MXUS has no improved copper fill referring to the "V3 3k turbo", than the QSV3 will eat it in terms of continuos power
macribs said:if the MXUS has no improved copper fill referring to the "V3 3k turbo", than the QSV3 will eat it in terms of continuos power
Copper losses is that possible for vito to get from his engineering team? If someone have a contact at mxus maybe mxus too can provide copper losses so a more correct comparison could be done?
None that I can see, not even the 4503, its pushing 11+kv, not 13+ like this one and the stator is 10mm narrower on the 5K. This motor is kind of a game changer as far as any DD motors that weigh under 35 pounds.markz said:Good stuff Teslanv, very good stuff!
Its going to be amotor
Can't wait to get my hands on it.
Hmmm which motor would be close on the ebikes.ca motor simulator?
