by slaphappygamer » Jan 25 2023 11:53am
I’m curious. I’m debating on wether, or not, to get a new suspension fork. I could get this motor…
Just a question, why do you need or want another motor? is the current one burn up or getting hot?
US $45.74 47% Off | 36V 350W Engine Motor Replacement for Xiaomi M365 Pro Electric Scooter Motor Wheel Scooter Accessories of Driving Wheels
https://a.aliexpress.com/_mNjIrkE
..and it would fit in my existing fork. The solid tire isn’t too bad. I’m looking at honeycomb tires, to see what else is out there. What I’m most curious about is if that motor will work with my controller. I got this kit….
Would not go to a solid tire, makes for a rough ride. Don't have enough information on the motor or controller, most should work, always a chance that it will not.
Vbestlife 36/48V 450W Electric Bicycle Brushless Motor Controller Kit, E-Bike Dual Drive Brushless Motor Controller with 866 LCD Display Panel for Electric Bicycle Scooter Accessory https://a.co/d/ejJHaD5
To off any help, what is it that you are wanting, more hill pulling power or speed?
…the regen is what I’m not sure about. The controller doesn’t support it, but the motor does. My concern is that the controller would take on extra heat with a motor that has regen. Since the controller does not support regen, maybe it won’t take that heat in? That is my question. This motor would be connected to the secondary controller.
Your understanding of motors is not correct. Most motors are dumb things unless they have something built in like a controller.
All motors support regen not a special function. The regeneration function is in the controller not the motor.
You spin a motor you can make electricity, coasting down hill, with your hand or an ebike by pedaling.
Getting the above motor will mean I won’t have to replace my fork and it makes economic sense, to me. Function is also key. The hills around me are pretty steep and a second motor would be greatly helpful.
Ok get it now you want two motors to get up the hills. Still would not want a solid tire.
Need to try to match the motors if not one would be doing all the work and get hot.
Need to make sure the wheel size is the same as the KV of the motors.
