Hello.
I have to say that I am a physics student, and not really a electrical engineer like a lot of you. Having said that, I hope you dont make to much fun of me when I get stuck on obvious electrical issues. I have been driving and hotrodding 9C`s for little over a year, and have kind of fallen in love with its simple, and cheap, construction (and its obvious limitations). I became a physics student for my love of challenging peoples individual "truths" about what is possible and what is not. I originaly planed to make this build all on my own, incognito, without community input, but realized I might need your hotwired brains to reach my goals.
Before build start I would greatly appreciate all input you might have for me to further map and adjust my goals and obvious obstacles! I am sure I have made mistakes in the planing, I just have not found them yet....
The project:
As the title the goal is to build the fastest (dragracing) 9C motor in existence. I do realize this is probably going to fail, but I want to make my crack at it never the less. I know most of you would have gone with a better motor, but the challenge is the fun part in my eyes. And if it works, the solutions could be transfered to any other more expensive and more potent DD hub.
Setting the Goal:
I have tried to look up and search for "the king of the hill" of 9C builds, but cant seem to figure out who holds the throne at the moment. All I know is that it must be here on this forum somewhere. I have not read it all so I am hoping for some input on who it might be, and what I am up against
As far as I have seen we are in the 6000 watt-area. If I am wrong, please rectify me so I can adjust my aim!
Obstacles:
Enemy nr 1: Heat:
- "normal" heat buildup
- "excessive" heat buildup due to copper mass limitations
Enemy nr 2: Constructional weakness:
- Danger of warping axle and center stator "frame"
- Danger of warping side covers
- Frying hall sensors
- Burning out copper wire after exceeding its assumed power potential
- Excessive strain on bearings that might lead to failure
- Ripping apart spoke-flanges and holes
- Magnets delaminating from external ring due to heat
Background:
I know a post like this might be observed as a newbie "just blowing smoke". But I did have a crack at the project once before. That time I got around to about 4500 watts using 20s LiPo`s (pushing just above 60A max) before the metal holding the inside of stator warped due to heat and rendered the motor totally destroyed. So this time I am starting from scratch, and hopefully with a bit of community input will get the 1500W+ I need
The project:
Setting the Goal:
Obstacles:
Enemy nr 1: Heat:
Background:
