thundercamel said:
They do not interlock, and I just cut them with scissors to the length I wanted. I put two strips of Quick Grip glue between each row of cells and the plastic spacer. Makes for a solid pack when done.
I still might end up going with what I have though, if space doesn't allow another parallel group.
It looks like I'm coming up on 7 months with the new setup with the Leaf laced in the 24" rim. Now I think 24" is just the right size and the Specialized plus sized tire has been a really good compromise, providing more cushion while not affecting my mileage too negatively. The tire is a legitimate 2.8" wide, and the rounded profile is good for cornering. The knobs are good enough to not lose traction on a 25 percent dirt hill, and perform well in mud, and decent on sand, so it works for any place I take my bike. Sand could be better, but at least I don't just flop over if I need to turn or maneuver.
I don't have an A/B comparison between the performance at 26" vs 24", since I laced the motor into the rim without every trying the 26", but the torque and acceleration continue to impress, even though I've been riding it a lot and used to it, and I'm guessing the slightly smaller rim just helps to improve those aspects. Plus, I only ride in low on the 3 speed switch, so limited to 4300W, which is also good for all of my riding, but there's more power available for a joy ride at the flip of the switch or changing the CA mode. I've actually decided that my eventual full suspension build will be with 24" wheels, which would allow me to go a size larger on the frame and still have manageable stand over height, and more room for the battery.
I did a quick ride out to Yerba Buena Island, in the middle of the SF bay, via the Bay Bridge on Saturday. 35 miles round trip with no side trips. The last time I rode there was a year and a half ago, with my old motor and the current frame
My econo-e-bike, and before that was with the first frame, my old steel mountain bike (pic in the first post). Similar shot, but they've done a lot of construction work on that part of the island, so not the exact spot as the first pic.
One of the reasons I rode there was to see the progress of construction was on the adjoining manmade island, Treasure Island, which was built for the world's fair over 100 years ago using earth dredged up from the bay floor. It was later turned into a naval base, with a lot of military housing. That's all being replaced by a multi-billion dollar housing complex, with probably the best panoramic views of SF that you could find. Well, it was depressing to see all of the greenery gone, palm trees ripped out, and leveled, and not much constructed yet, plus they've blocked all of the access so I could ride around down there. Hopefully it will look nicer next time. This pic is from the top of the hill of Yerba Buena:
I ended up riding around Yerba Buena, which I never have before. I checked out the construction going on there, and stayed just ahead of the cops and security guards patrolling the area. I only had one security guard give me the "private property" routine, but he was cool and I just asked about the construction and what they were building. There was some pretty spectacular views of the bridge from below, so I snapped a bunch of those. It was a good way to spend a few hours on a day with perfect weather.
Here's a video riding up to the bridge, then over to Yerba Buena island. I generally ride pretty slow, 15mph, so I fast forwarded the video in a few spots:
I was at a little over half charge of my normal charge/discharge cycle routine (4.1V down to 3.7V) when I got home, thanks to the Leaf's efficiency! My butt can only handle about 50 miles, so I'm never worrying about the battery anyway, but I'm not tearing around at full throttle either. On this trip, I had mixed riding, but weighted toward more pedaling on the way there and more throttle on the island and on the way back. So more battery than I really need and more power than I ever use, so just right :lol:
As far as my winter upgrades go, I didn't get around to switching to hydraulic brakes, and haven't redone my connector box, and also failed to install my new used freewheel. There's probably a few more things I didn't do, but now it's riding season, so most of that will wait for winter.
EDIT: Looking at the bike as it sits today, I think the only parts remaining from the initial build, are the cranks, bottom bracket and rear derailleur. Everything else has been upgraded at least once, LOL.
