avandalen
I use A123 LiFePO4, with a capacitive balancing BMS. 24V is a good idea. Although the loss is higher due to the higher currents in the motor regulation, cables etc. But because of shadow, the PV panel voltage is much lower sometimes and here a battery voltage of 24V is critical.dodjob said:mmm :-/
What kind of battery chemistry are you intending to use? I fear that the battery won't like it at all. Do you use a BMS? if it's the case I do think it will go crazy because of the voltage's difference between cells. If not, you will more than probably have shitty performances and short cell life because of non equal load on every cells.
I woud really advise you to go for a 8S setting (24V). If you do, you will have a 40V no-load, 33.6V optimal on the module side and a standard (setted) 24V MPPT 250W on the other side. You would be done
Gruß,
H.
Albert
