Chalo said:I gotta say, that's not a motor for folks with a prurient interest in performance. It's just a motor, adequate for hauling around a medium-sized person at 20 mph or so in ordinary street conditions. If you're inclined to maximize it for whatever reason, you'll probably break it.
It might be off a bit. My rear tire wears even faster though? I'm on my 4th rear tire (the first three were the cheap tires the trike shipped with....fourth is a wider Marathon and is holding up well).Comrade said:pullin-gs said:This is what Schwalbe Marathon tires look like after 4,000 miles
Are you sure your alignment is good? I have only 1,000 miles on my Terratrike but I can still see the factory ridge in the center of the tire from the rubber mold.
Please share a dyno graph for another 5lb (or less) 1000W motor.neptronix said:I've seen dyno graphs for the Q128C before and can say with confidence that there are much better motors on the market with better efficiency and power to weight.
pullin-gs said:Please share a dyno graph for another 5lb (or less) 1000W motor.
Q128C comes in 800W variant. https://bmsbattery.com/motor/1130-18552-q128c-135mm-36v800w-cst-rear-driving-ebike-hub-motor.html#/213-rpm-201neptronix said:The Q128C is a 6.6lb 500W rated motor. Like i said, and aerodynamic advantage. That says more about your vehicle than the motor.
Again, motor is rated 800W.neptronix said:Also, you say 1000 watts, when that's your peak rating, not your continuous load. Motors are rated based on continuous load, not peak. Your continuous load as you describe it is within the 500w rating on flat ground.
pullin-gs said:Q128C comes in 800W variant. https://bmsbattery.com/motor/1130-18552-q128c-135mm-36v800w-cst-rear-driving-ebike-hub-motor.html#/213-rpm-201
pullin-gs said:And as far as "you're getting more wattage out of it because of your small wheel "....
Watts are watts. Wheel size, ride platform have nothing to do with getting more watts or not out of a motor.
Maybe you meant to say "speed at given wattage is better relative to other rides because of the aero performance of your trike"?
neptronix said:pullin-gs said:Q128C comes in 800W variant. https://bmsbattery.com/motor/1130-18552-q128c-135mm-36v800w-cst-rear-driving-ebike-hub-motor.html#/213-rpm-201
That's another one i saw a disappointing dyno sheet for, where the motor really couldn't handle the 800w. The results on the Q128H were even worse. BMS battery really tends to overstate things and also has progressively been removing dyno sheets because they contradict the company's ratings..![]()
pullin-gs said:I'd love to see these dyno sheets? Please do share!![]()
When it comes right down to it, you can talk-the-talk (quote other peoples dyno sheets and results) or purpose build and engineer based on requirements and stated vendor performance and first-person OBSERVED performance from other builders.
pullin-gs said:My requirement: 20MPH on flat, but very light (mid-drive and direct drive out of question). For me, that translates to 350watts minimum just to push through the air on flat. Add into that 6 percent hills (I have a many of those in my area....but only one that is steeper) and I need 800W AT THE WHEEL to sustain 19 MPH. The trike does this all day. Hills are only 1/4 mile max, so peak heat a non-issue.
pullin-gs said:Now on the other hand, If I need lots more power and low end torque for a beefier ride, take a look at my 2KW gear-drive fat build to see how I figured things out for it.
https://endless-sphere.com/forums/viewtopic.php?f=6&t=111042&p=1627643&hilit=G062#p1627643
https://www.youtube.com/watch?v=v9e7vcZStVw
Indeed! Now if they would only let you mix up ratios & windings!neptronix said:Those wide bafangs are pretty magical.![]()
pullin-gs said:Indeed! Now if they would only let you mix up ratios & windings!
I took a big gamble going with a new model Bafang gear motor. I jumped because of other people observing that Bafang 750W rated gear motors are actually rated under what motor can safely handle.neptronix said:pullin-gs said:Indeed! Now if they would only let you mix up ratios & windings!
That's one of the reasons i generally avoid bafang products.. that and the lack of published performance specifications.
Vetting a new motor from them is about on par with the alibaba no-name vendor mystery motor buying experience.. except that the company has a name.
