Jan-Erik-86
- Joined
- Jan 23, 2019
- Messages
- 110
Thank you very much for the reply Pajda, that explains a lot!
I must admit the VTC6 performed much better then i had thought, and so i am actually leaning a little bit back to that now.
First of all, 70% capacity after 1000 cycles in itself would be enough (would take me 5 years, at least), but i also won't use even close to 100% DoD. How is your test on a lower DoD doing so far?
I know now that i get more "bang for the buck" with a PF/29E cell, as the VTC6 is ~30% more expensive and have a worse cycle life, but with the higher discharge voltage of the VTC6, even though it looses more % of Ah then for example a PF/29E in a cycle test, won't the actual Wh compensate a little for it?
While i want the battery to last some years, i also want to have fun, and it's not fun if i have 30% capacity left on a 3 year old battery, hit the throttle and reach LVC. For me that's the same as having 30% less capacity left, even if i could theoretically pedal home in lowest power setting. Do i risk this being the case with a a PF/29E?
