PJD said:Bob,
Another question.
Some SLA chargers, for some reason, need to detect a certain minimum amount of voltage at their output before they turn on. This is often discovered when attempting to charge a pack that is completely dead. How will this affect the usage of such a charger with your BMS? Any work-around?
when first connected, the fet in the negative charger lead will be full on, so the charger should start if the pack would start without the bms.
when the bms is powered on, if any cell is below 2.1v the charger will start with the current reduced to the value used during shunt activation. The cell needs to be up above about a volt before it can be detected as low voltage, so the system is not perfect.
the best workaround is to find the weak cells and bring them up with a current limited supply, like the kit i am providing that runs from 1-25v DC out @ 1.5 A cont.
PJD said:Bob,
Another question.
