New Bafang Crank-Drives
The limiter is software controlled in the LCD. It is not a hardware limiter. Lecrewse was able to obtain a limiter removed version from the supplier.
Second issue is the throttle maximum is also limited to each PAS setting. So let's say PAS mode 1, 2, and 3 have a top speed of 10, 15, and 20mph respectively. Then even if you use throttle, the maximum throttle speed can only go as fast as the PAS mode that you are in. Again, lecrewse sells a version where the throttle max is independent of the PAS setting. So anytime you use throttle, you will get full top speed.
The third issue is that these kits ONLY come with PAS engaged all the time. That means once you start pedaling, the motor (PAS) will kick in. However, this is an easy fix. You just open up the motor to disconnect the PAS sensor. Of course, you'd lose PAS. There is no way to disable the PAS in the LCD, unless of course, you get a kit that can be disabled.
I wonder about this statement. This is most definitely a US version as a 750w setup is illegal in Europe. AFAIK it is currently legal to 250w. Correct me if I am wrong. Your girlfriends bike is also 36v as it states in your sig and that may be why you have these issues. As this is 750w a PAS is not required and I would think that this would have to be altered. Also the stated high speed is 40-45 kmh(28mph). Not that the chinese would lie about this. :roll: Lecrewse's Ebay auction states: Top speed 25mph using throttle and 27mph+ using pedal assist function. I don't know why they would limit the speed on this other than to sell legal kits to Europe. Makes no sense to me. If Lecrewse got them to change things, I am sure anyone here could do the same. There are some real advantages to buying from someone that actually has the product on hand and is stateside though. Lecrewse also has twist throttles instead of those cheap thumb throttles - I hated mine that lasted only a week. I am not trying to cut into his sales -as you are taking the risk upon yourself to order anything from Aliexpress. That might not be worth the money saved. Just depends on how cheap/risky you are. I really just don't think he was able to get some different version that they wouldn't sell to anyone else.
I personally am holding off on buying a kit anytime soon since snow is right around the corner for me. I emailed them about the throttle limiter and will post if they get back to me. I want to put this on a big hit, so I am hoping the product is going to hold up to abuse.
By the way Rollodo - what is a green wave?
The speed is normaley limited to 35km/h max but you could set the Display to have the tire size so it is running faster ;)
A green wave is a common term drivers use to describe a condition where you get one or multiple green lights in a row (usually in a straight line), and by the time you reach that last green light right before the red, the red one also turns green. Drivers often have to keep their speed up to a certain level to reach this effect, and once they do, the green wave almost always puts a smile on their face, be it physical or psychological.
I just got the reply. They said they can set the max speed according to customers request, but they are the US version, whatever that means. I might just have to order one. I was actually at the bike shop yesterday and showed my wife the price of the new bikes. My hobbies are cheap in comparison. I can't believe people pay 8k for a bike. Makes all the stealth bikes seem cheap for what you get. I would rather get a dirt bike for that money.
Green wave - I thought that is likely what it meant an hour or so after I posted. Don't have that issue here :lol: Thanks
Update on BBS01.
We've now gotten to the point where we will be selling all our bikes with front and rear hub motor kits and shifting over to Bafang BBS01 mid mount bottom bracket motors for all our bikes (we have six guest bikes). Because we visited the factory in January, hosted their rep in NZ, offered to test out the prototypes and to edit the user manuals for native English, we have been able to develop a good working relationship. We've made a number of suggestions for improvements, and the factory is receptive.
Most recently, when word got out that we planned to put an order in for motors, others asked if they could join in a group purchase. We are now up to 22 motors, with one more person who called tonight hoping to get in before the cut-off (which we hoped would be tomorrow). The factory will be setting 17 of them for New Zealand legal, 300W, no limiter and thumb throttle. I was tempted to order one of the 750W 48v motors, but I don't do off road, so I'll let someone else report on the big boy. Bafang does say that it is designed for tricycles and utility bikes as it can stress the chain, but I expect Americans will be ordering it for their regular bikes in states where 750W is legal.
We have asked Bafang that some of our motors do not come with the C961 display, but instead are programmed for a simple on-off switch and a 1-2-3 switch to give partial and full speed. The display is nice, and it has lots of useful features like speed and distance, but for guest bikes (or for dealers who don't want to see broken returns), it's one less thing to break and a simple switch is lot easier to replace locally if it does get damaged. Already the BBS01 has built in the controller and pedalec, which means less things to strap on the bike, and fewer cables.
Many of these questions on this thread have to do with factory settings. In other words, the restrictions are software programmed, not hardware limitations. Unlike our enthusiast vendors who encourage hacking by supplying USB cables and in some cases the software, Bafang prefers to set the motors at the factory and discourage hacking. But as they learn the market, they are able to set them for each different country. Our law says 300W max, but nothing more. No speed limiter. We found with hub motors 300W without gearing was inadequate because of our Swiss-style hills. With the BBS01 that uses the bikes gears, we found that even the Eurospec 250W works fine, but appreciate that Bafang will be setting up our batch to be max legal in NZ. As they learn the other markets, I expect they will do the same for each.
Speaking of gears, all our bikes are internal hub gears, either Shimano Nexus or Sturmey Archer (AB & S3X). They are not designed to be shifted under power, which means that chain has to stop moving. The motor has lag, thus when you stop pedalling, you have to wait until the motor stops... going up a hill, this means losing momentum. The ideal solution will be a sensor in the motor that cuts power as soon as the cranks stop turning. We have proposed a work-around where an instant-off button on the handlebar is spliced into the ebrake, because if you touch the ebrake, the motor instantly quits. The challenge going up a hill is to goose the brake just enough to cut power, but not slow the bike; pressing a red button would be like an electronic clutch. We'll report on it, if we get it in the next batch. The other way to go is to install the NuVinci N360 transmission hub that can be shifted under power. NuVinci will warrant the N360 with a 250W motor. At 2.45 kg, it weighs more than the battery, but it does sound like the perfect match to the BBS01. It also can be installed with a roller brake. We've bought one and had it laced to a 28" roadster wheel (635mm), and will report when we get it back on the 1951 Raleigh DL-1. We also had a SA X-FDD front brake/dynamo hub laced into a new rim (both original rims were knackered) which will give new life to a great frame. Now, it's awaiting a free day for me to sand down and hand paint the frame with Hammerite black. It will be heavy (actually the stripped frame is not heavy... its the steel wheels, 28x 1 1/2" tyres and the hubs that will make it a brick), but it will be ridden, not carried and the motor will deal to the tonnage.
For this order, we are going with the Cellman 29E 36v battery. It's small and light compared to the older generation batteries, small enough that it can fit into a saddlebag and further increase the stealth quality of the bike. While the motor sits in full view for those in the know, it actually looks like part of the bottom bracket and it quite fools most people when mounted on a classic European town bike like the Gazelle or the Bella Ciao. We hide the battery in a Brooks Millbrook saddlebag that is placed on the front handlebar. In our emails to Paul, he made it clear that if we can ship 20kg volumes, the shipping works out reasonably for each battery. Thus, if we order in increments of 9 batteries (just under 20kg), the cost per battery is not at all bad. At last count we were at 16 batteries, and I'll probably make up the difference if more orders don't come in in the next 24 hours.
This volume of orders came through word of mouth and a single article in our local paper. We have a population of 8,000. While group buys can be a pain to coordinate, it is a good way to save money especially on shipping. It seems that some of the online Chinese vendors, which offer really cheap prices, are making their profits back on exorbitant shipping costs. Cellman does not play that game. So, if you are on a tight budget, put the word out and see if a group buy comes together. Just make sure you get your pricing right, and maintain really good communications with your buyers, so they understand you are not a vendor, but an order coordinator. Also, if you are not dealing in USD, make sure you provide for a drop in your local currency.
Bottom line: We love the BBS01. It is a game changer, and we expect it may become a huge seller. Because Bafang sells them designed as an after market kit, you can expect substantial market growth. Interestingly in our small sampling 8 buyers were women, four men. This is very different than the demographics of this forum. Our experience suggests that the huge untapped market is female... not looking for massive power or hackability, but "invisible riding" meaning you pedal, it adds power, it makes going up hills easy, and all you do is plug it in every night.
Yes, Most traffic lights are often synchronized to do this to allow smoother traffic flow through congested areas in larger cities and even the suburbs.
Does anybody happen to know whether the controller in the bbs01 has low voltage cut off? I've ordered the 750w 48a version and I'm hoping to use it in conjunction with Sony konion v3 cells since they are high power and I like the idea of not needing a bms, though they do require some sort of LVC to protect the cells....
Just to give an update on the BBS-01 and BBS-02. I've secured the software to re-program the controllers and will be detailing a few different customization options that I will be offering to my customers soon. This includes things like adjusting the number of and percentage of current available on PAS assist levels, lvc, removing speed limiter, etc.
I actually think it's a good idea to try out the programming options on a small group of beta-testers before making any info more widely available. Just saying that "this is the program that the company gave me", and it's not your fault that a high percentage of the customers motors/controllers are frying...I just advise caution, and one step at a time.
The advantage is that on a hill, the 750W will not slow down as much (you can maintain your top speed in a higher gear). At lower speeds on flatter ground, both drives should draw about the same watts.
If you live in a reasonably flat area, the 350W version should be more than adequate. If you live where there are significant hills, you will not regret getting the higher power unit.
I see, makes sense. Thanks, man.
Does anyone know the difference between the BBS-01 and the BBS-02? I can't seem to find that. I did read somewhere there was a water ingress issue that had been fixed. I don't know if that is what had changed. Likely putting an order in soon, so if anyone can chime in quick it would be much appreciated.
EDIT: The information in this post is under dispute, we are now waiting for verification from members with "hands-on" access to actual drives.
I believe the BBS-01 is the 36V / 350w unit, and the BBS-02 is the 48V / 750W unit. The 48V / BBS-02 motor is wound to a lower kV so it provides the same RPMs as the 36V unit (that way they both use the same mechanical parts), and the S02 stator is also wider to give it more copper mass and torque per watt.
Both options I am looking at are 48v 750 watt. CNE bikes has the BBS-02 and General Electronics Battery (no relation to GE? :lol: ) has the BBS-01. General Electronics will remove the limiter, didn't ask at CNE.
The forum search is lousy. Found this from a google search on the forum, page 2 of this exact thread:
Countermark serial number on motor casing as following:
BBS01 36V 250W
15A 25km/h
13010001
1. BBS01: motor type(speed sensor);
BBS02: motor type(speed sensor with coaster brake);
BBT: motor type (torque sensor)
2. “36V”: rated voltage; 250W: rated power.
3. “15A”: limited current, 25km/h: max speed.
4. “1301”: production date, produced in January of 2013.
5. “0001”: serial number.
I really don't want to get the coaster brake version. Is this accurate info?
I checked the em3ev.com site and didn't see a specific listing for the battery that was mentioned: Cellman 29E 36v. Do you have the size, weight and AH for it?
I have his (now) older 18.5 AH battery and 10T motor. Really like the setup.
Thanks!
According to one reseller the above was the correct answer. There are many listings for the 48v 750w unit under the BBS-01 name though. CNE bikes stated that both the BBS-01 and BBS-02 versions do not have coaster brakes.
Sometimes re-sellers "think" they know the details of what they are selling, but they labor under several misunderstandings...this is yet another reason why endless-sphere is so valuable, once some of these units get into our members hands, we can find out the raw truth. A friend is about to pop apart a 350W and a 750W to see what internal physical differences there are...
I saw pics in the french forum, the 48V unit seems to have bigger transmission... But I would be happy to see some pictures where they are next to each other.
Communications with CNEBIKES is a nightmare... ordered 26 sept and still have not sent the motor?
Ordered on 26 sept and they said motor will sent asap.
-36v 350w 8-fun mid motor is whole priced usd350 ( 48 T )
-36V 9AH tubelthium battery + charger is price usd150
-The freight for the all is usd125 via the ems
Email them 18 Oct about the tracking/shipping status and response from CNEBIKE:
-Dear . i had sent you the motor to express company yesterday . i think they will received it today or tomorrow . pls don't worry . they will send you
-immediately when they arrived it .
I am not 100% sure what they meant? So they just started shipping after 3 weeks..WTF.
Amy from GE is saying the motor is exactly the same for 250/350/750W
