@hoka,hoka said:Here is my 750 watts build:
A Bafang technician is going to come to re-program the motor for Throttle use and I am trying to find out what possibilities there are so I can have him do it exactly the way I want it. Does anyone know what the programming possibilities are?
usf_tim said:Not sure if i want to get the motor from aliexpress or from lectriccycles. Looks like its about 40% more from lectriccycles but they are in US and can do some firmware changes on the controller. They also have free shipping on their batteries so not sure what is the best deal all around.
Thanks
Tim
It says that the pack's discharge current is recommended as 20A continuous, the motor controller draws 25A max. Do you see yourself pushing the motor to its limits at all times? I guess it all depends on the gearing you use, but that the beauty of mid drives, as the user isn't limited to the gearing, as is the case with hubs.usf_tim said:http://em3ev.com/store/index.php?route=product/product&path=35&product_id=161
Has anyone tried this battery with 750W motor? Will this pack be able to handle the current? Does anyone know what em3ev charges for shipping to US?
http://www.aliexpress.com/item/48v-750w-8fun-bafang-bafun-BBS02-Electric-bicycle-motor-crank-shaft-motor-conversion-kits/1326047038.html
http://lectriccycles.com/products/750-watt-mid-drive-conversion-kit
This. Backlog talks to the kit's popularity.teslanv said:I bought mine from lectriccycles.com and have no regrets. Fast shipping (however now they have a three-week backlog), excellent customer service, custom programming, free shipping.
Seems like there are several reports of lock-rings loosening and other indications that the drive might be moving around in the shell. I'm starting to suspect that this mounting system is not up to the job. Bottom brackets take a lot of force from the rider both pedaling and from standing on the pedals over bumps. It seems like a lot to ask from a pair of lockrings to hold all that in place with no motion. Perhaps the drive needs to be bonded or molded into the shell somehow for a more secure fit.footloose said:Maybe more concerning: there was some evidence that the torque of motor had in fact been rotating the entire assembly slightly within the BB shell. I expected to find a single, sharp, V-shaped indentation in the steel of BB shell from each of the mounting plate ‘protrusions’. In fact, I found that each of the indentations was a bit wider than expected. Instead of a perfect V shape… each indentation was shaped more like \_/ That is, each of the indentations was slightly wider than expected.Rusty123 said:The latter is basically the case -- the axle assemble is inserted into the BB shell, with a threaded retaining ring (and a locking ring, depending on BB width) compressing the unit against the BB faces. The internal threads on the BB shell do not come into play.deepfraught said:Does the installation use the bottom bracket threads, or does it thread one side of itself into the other, floating in the BB and clamping itself to the faces?
Retaining ring and locking ring were torqued down tight when originally installed, the BBS02 was not movable by hand force, and the retaining ring and locking ring showed no signs of having loosened since the original installation. My best guess is that the power of the motor was resulting in very slight rotation of the entire assembly within the BB shell over time... eg, the mounting bracket 'protrusions' weren't sufficient keep it perfectly static, and the steel of BB was deforming slightly over time. If so, that is kind of worrisome.
Good ol' hammer works wonders.teslanv said:I have to wonder if those with loose nuts had used the correct spanner wrench when tightening, or something else like a pipe wrench or ???
Samd said:That's a relief to hear Kepler. Is your BB Steel or Ally?
Geebee said:... the system was designed for 250w and then modified to 750w due to demand and most likely never tested for trials riding for some reason
Kepler said:Was feeling a bit lazy today and comuted with the bike at 35kph to 40kph using the throttle button on level 5 to 7 out of nine. The day was warm at around 30 degC and the trip a leisurely 15km
Got home and checked the motor temp. Motor was hot to the touch to a point you wanted to take your hand off the case. Measured with an IR temp gun and it was 55 degC. Although this is not a temp that will burn the motor out, my experience with hub motors is that a case temp 60 degC is getting close to damaging levels.
If you plan to run the 750 Watt BBS02 at its maximum level, I strongly advise you keep it to short bursts.
IMO, this drive is not a good choice for the person looking for a high performance and sustained speed above 40kph. However, use the PAS predominantly and throttle in bursts and you will be rewarded with an excellent riding experience.
Thanks that could also work. Only drum front and.coaster single speed rear so speed limited lower power is a good ideaspeedmd said:If you did not want to grind away enough material in the center rib to clear the motor you could add something like problem solver for low power apps. if you could find a suitable position.
Cinelab said:Wondering if the BBS02 would fit on a Mongoose Beast.
BB on the Bbeast is 110mm.
Is there a way to make it fit?
Maybe using one of these above.
Melbourne said:Kepler said:Was feeling a bit lazy today and comuted with the bike at 35kph to 40kph using the throttle button on level 5 to 7 out of nine. The day was warm at around 30 degC and the trip a leisurely 15km
hi kepler
This include 350w36v? I ran max level (throttled)on the 40degC days when it was tooo hot and lazy to cycle? didnt have equip to check, but yep very hot to touch.
teslanv said:Kepler said:Was feeling a bit lazy today and comuted with the bike at 35kph to 40kph using the throttle button on level 5 to 7 out of nine. The day was warm at around 30 degC and the trip a leisurely 15km
Kepler,
What Voltage battery are you running? - What kind of watts were you pushing through it?
