spinningmagnets
100 TW
Thanks for the video link! There was a BBS01 installation video in the associated links column:
http://www.youtube.com/watch?v=irmyv9G9WyU
spinningmagnets said:There are two reductions, the primary is a helical set of gears (seen at 2:22), Its not clear, but I will estimate the steel motor-sprocket is an 8T, and the other larger nylon gear is definitely a 32T (4:1). The secondary is a small pinion driving the larger diameter gear, and the secondaries do have straight-cut gears. At 0:21 it looks like 68T and 11T (6.18:1)
6.18 X 4 = a total reduction of 24.7:1
The 250W and 350W are the same size.Arbol said:Does anybody know if the 250W and 350W motors are the same physically, just with different controller settings, or if the 350W is different (I imagine bigger) than the 250W one?
nippynoo said:The 250W and 350W are the same size.Arbol said:Does anybody know if the 250W and 350W motors are the same physically, just with different controller settings, or if the 350W is different (I imagine bigger) than the 250W one?
Here's a drawing showing both : http://www.bike-emotion.org/BBS01 tech. Zeichnung.PDF
Motor casing diameter = 111mm
spinningmagnets said:Do you want to add a smaller chainring than the stock unit, or a larger one for higher top-speed on flat land? perhaps you want two chainrings that are different from the existing stock chainring?
Arbol said:nippynoo said:The 250W and 350W are the same size.Arbol said:Does anybody know if the 250W and 350W motors are the same physically, just with different controller settings, or if the 350W is different (I imagine bigger) than the 250W one?
So, you are saying the 250W and the 350W are in fact the same motor, just that with different stamps? And the 500W is physically more powerful? Or you are not saying so much?
Sounds like pure BS too me because it is threaded on both sides of the bottom bracket in other words you have to thread it into the frame of the bottom bracket.nippynoo said:Just been discussing the fitting of the Bafang BBS01 with a bike-mechanic at my LBS and he warned me that the bafang doesn't use the threads in the bottom bracket, only pressure plates at each end, so there would eventually be a tiny bit of free play, caused by the shaft alternately pressing on the outermost threads whenever pedalling torque is applied. He says the threads in the bottom bracket would soon be knackered by this repeated movement of the shaft. The pedalling forces are quite high and the threads would become damaged. And it would eventually knacker the frame itself, maybe a fatigue crack around the bottom bracket housing. Is there anyting in what he says? He actually doesnt want to sell me an expensive bike to try the conversion, but is recommending I buy a much cheaper (heavier/solid) bike as he's convinced the bottom bracket housing wont last long. Anyone care to comment?
Not true. The BBS01 just slides in. Then there is a nut on one side only. Watch this video and you'll see how the threads are not used..wineboyrider said:nippynoo said:Sounds like pure BS too me because it is threaded on both sides of the bottom bracket in other words you have to thread it into the frame of the bottom bracket.
speedmd said:Typical LBS stuff. On a soft, not heat treated aluminum frame the threads could get beat up quickly if the the assembly is allowed to run loose and move around. If snugged down the movement will be kept in check and very little thread flattening should occur. If your worried about it just wrap tape around the bb insert so the threads are snugly against soft material, or use a softer/ weaker loctite thread sealer to help fill the voids and give you more support area, and kill any chance of movement. You will hear lots of noise if loose so you will get warning before anything gets trashed assuming you don't ride with buds in your ears.![]()
speedmd said:This kit has a self supported BB within the bike bb shell. Not the same thing. No slop in bearings. The shell should lock up very well and not relying on the bikes bb threads to maintain bearing tolerances. It acts more as a solid. Filler, most any most likely will eliminate any slop between the two shells. Tell Orvil he has nothing to worry about unless it is loose.
