sacko
Matthijs said:
Has anybody bought this?
..or had any communications with them?
Matthijs said:
--freeride-- said:Nice fatbike! What frame is that, that you could fit the Bafang in?
lcrewse said:--freeride-- said:Nice fatbike! What frame is that, that you could fit the Bafang in?
It's a modified Origin 8 Crawler. Going to be producing a fat frame to accommodate this exact drivetrain in the very near future and modified this bike to test everything out. There was cutting, grinding and welding involved in order to get it to fit. I also had to machine some adapters to be able to have a proper chainline and use a standard mountain chainring.
--freeride-- said:lcrewse said:--freeride-- said:Nice fatbike! What frame is that, that you could fit the Bafang in?
Thanks, grinding, welding and some adapters, thats what i thought.
So the crankarms of the bbs01 are wide enough to go passt the wide chainstays of a fatbike without modifications?
Then it may be possible (again with grinding welding and some adapters) to build an Surly pugsley in your configuration
What is the Cadence of the 750W Unit like, the 250w 36V Unit seems to stay around 80-90rpm. Are the 48V units faster? I am used to pedal fast like 100-110rpm so that would be perfekt for me![]()
Gab said:Hi How heavy is the 48v 11ah battery ? It has a nice shape and lots of capacity .
and also what is the max current available from the battery ? Can it be used on another type of ebike ?
cruiser0002 said:Can you use your own crank set and front derailleur with the bbs01?
crossbreak said:this is not possible with any middrive. Front derailleur are something special, too. Most times you wont need it anyway.
cruiser0002 said:crossbreak said:this is not possible with any middrive. Front derailleur are something special, too. Most times you wont need it anyway.
Is this because the BBS01 does not use a standard chainring?
lcrewse said:cruiser0002 said:crossbreak said:this is not possible with any middrive. Front derailleur are something special, too. Most times you wont need it anyway.
It does use a non standard chainring, but the reason that mid drives in general can't use a standard crankset is that the chainring needs to freewheel separately from the crank arms. This allows the motor to drive the chainring without the rider having to pedal.
wojtek said:how loud is it comparing to cyclone and similar please?
crossbreak said:the 1000€ are not worth the 42T first gear IMO. You will hardly use it. The 10T gear will be waste within few miles if serious power is run through. The cassette at 250€ is a bit expensive to swap it after few miles
I can recommend the 12-36T CS-HG-61 cassette, really heavy (450g) but really durable. Works with virtually any derailleur.
