DaveTheWave
Kepler - thanks for the confirmation. So much to learn about this stuff...
t3sla said:I believe they are using the same model naming style as hub motors.
So a BPM 350W and a BPM 500W is still a BPM
BBS01 is still the same for model name for 250W to 750W
I think this was all conceived before 750W entered a production, because it mechanically different form a 250/350 and warrants a variationin naming (unlike that of it's BPM counterpart)
lcrewse said:nukezero said:On a side note, looks like bafang uses three different types of LCDs. I wonder what's the difference with the third one. The second one seems the nicest of all but I'm super concerned of theft. It's very fancy. The C950 which is what I have would appeal to less people as it shows vel, odo, dst. To someone in the US, that probably just means it is some kind of speedemeter and distance measurement screen. Probably wouldn't steal it as much as the chrome-bezel looking C961.
The C963 also seems a bit fancy with the piano black finish.
The downside to my C950 is the fixed KM/H display.
The C963 has real time power info (in watts) but also only displays in km/h and has a small but high quality screen. The C961 has the 6 hex bolts securing it and the controls onto the handlebar. Unless someone wants to remove all 6 bolts and steal a display with a proprietary plug that will work with nothing else, I think it's a non-issue. That is of course, unless someone with the same drive system but an inferior display, a bike multitool and a lack of morality happens to encounter an unattended bike with the BBS system :lol:
Goodies said:A couple of questions about the bbs-01.
Does it work without the display/throttle. If so what PAS level does it default to?
Does it work without the speed sensor, and just a throttle?
Where can one order the larger 52t chain wheel?
Goodies said:Where can one order the larger 52t chain wheel?
Samd said:SRAM dual drive? IGH plus derailleur?
http://www.sram.com/sram/urban/products/sram-dd3-24
I think IGH only runs about 92% efficiency, versus about 98% for a derailleur. Some folks may care?
Kepler said:Those IGH units weigh close to a small geared hub and don't shift under load.
Melbourne said:Display-No Throttle-Yes most likely not work without the display ..but why won't you use the display? you can't turn on the motor/change settings!
