zzmatias said:
Hi Kepler,
Since you have ridden both Bafang’s mid and geared-hub drives. I’d be interested to know which one would be your favorite and any reasons.
I know they are different, and that the mid-drive would provide more torque for steep hills and perhaps is a bit quieter but slightly heavier and not sure if I could connect a Cycle Analyst and get the most of a 45V 12S pack.
Thanks,
Matias
I'm not Kepler, but I have bought:
- (1) Bafang SWXK5 front motor
- (2) Bafang CST 700c rear hub motors
- (1) Bafang BBS01 250W Eurospec prototype (aluminium shaft)
- (1) Bafang BBS01 300W (350 reset to be legal in NZ) prototype (aluminium shaft)
- (23) Bafang BBS01 300W steel shaft motors with C691 display (we will keep seven for our bikes, the rest went to the buyers who joined out buyers group)
- (1) Bafang BBS01 350W steel shaft motor with a C695 display - this last one was a "try-it-out" from the factory and we like it the best
We are selling all our hub motors (also includes a Mac rear hub 500W, 50v, a CUTE 100F 350W (ha!)/36v and a MXUS 350W/36v front hub). We will be shifting completely to the mid-mount Bafang BBS01 motors.
Why?
The BBS01 is far less cluttered, amazingly quiet, very subtle, and it uses the gears. A hub motor is like driving a car with one gear, you either have to buy for torque or for top speed or buy an overpowered unit that turns your bike into a moped. I'm not sure how they did it, but the BBS01 is engineered differently than hub motors. It will tolerate slower RPM's, thus the 18a limit is OK. We find the range of a three-speed internal hub is sufficient, but the most interesting is installed with a NuVinci N360 hub that can be shifted while the motor is driving the chain.
It installs like an OEM kit. Indeed, we installed a number of them on Pashley classic city bikes and it is hard to tell that they did not come from the factory with the motor. The fact that the controller is inside the motor means one less device to attach, and in our experience the hub motors end up with a spaghetti mess of cables and wires. Each of those wires on a hub motor is one more thing to go bad in real-world conditions. In contrast, the BBS01 has three cables coming from the motor. One to the rear speed sensor, one to the battery and one multi-cable that goes to the handlebar where it splits into four... two ebrake, one display/speed setting and one (optional) thumb throttle (TT). After a bit of use however, we are not sure the TT is necessary. The pedal assist is good enough that find we don't use the TT except when looking to get a jump start into traffic.
It has a low and mid-point center-of-gravity, and with Cell-Man's new 29E Samsung batteries (2.0kg/11.2Ah), we can strap the battery to the lower seat tube for perfect weight and balance. We also found a $12 (NZD) new army bag that was a perfect fit for the battery, so it really is a very stealth-like look. The motor is small, and it is low and out of the way.
Having visited the Bafang factory, they are making some major automation changes. The old motors were hand assembled. The new stuff is being done on automated precision systems.
There still are some areas of fine tuning.
- They need to decouple the thumb throttle from the pedalec so it gets 100% power even if the display is set to zero PAS.
- They need a real torque sensor so it is instant on and instant off rather than the second delay. We hear this is coming.
- They should allow more field programming by qualified persons
- They should provide the option of no digital display, but only a On/Off switch with the 1-2-3 power setting. The digital display will be the first thing to fail.
- They need a better spacer for the display. It does not fit standard handlebars right, thus the installer has to use tape
BTW, not sure if you noticed, but CellMan has posted this news item "
There are a few new products in the pipeline, including the popular Bafang BBS02 mid drive kits (in 36V, 350W and 48V, 750W flavours initially), due mid-February, hopefully not too much later." We had something to do with that one, and are very pleased that he will be offering them. Mid-February is coming up soon.
