I posted earlier in the summer that my Davinci e-scooter (similar to Motorino) just stopped working one day. The ignition turned on, the lights worked but the throttle did nothing. I figured it was the throttle as mine was a little beat up. It was just a throttle with a killswitch. I bought a new one that didn't have the killswitch but had a 3-speed button. My bike had been rebuilt a few times before me and had been set to one speed thus not requiring the 3-speed switcher. Once I hooked it up and realized I wasn't getting proper meter readings I took apart controller to have a look and saw that it was blown everywhere. I ordered a new controller.
Now, previously I had been running a 60v controller with 72 volts of battery and charging with a 72-volt charger. It had worked fine for a couple of years. I decided to get a 72v controller this time. I had an option for 800watts or 1000 watts. I thought I chose the 1000 watts but when it arrived I saw it was 800. I don't know anything about watts and don't know if that could make a difference but when I check continuity on everything, every hall, phase, all connecting wires, throttle, etc. all is good but I turn the throttle and nothing happens. I have a new rear hub motor wheel and it tested good oo. Why won't the freakin thing turn my rear wheel??? I'm at my witts end and all I can think it might be now is that I didn't connect the throttle to the speed switch wire coming from the new controller. Would that make the difference since my bike was only an "on /off" throttle and now I need it to shift? I have 6 wires coming from the throttle and not sure what to do next. HELP ME PLEASE!
