Lenk42602
watcha writin?
mlrosier said:On a side note, I'm super anxious to ride. Would I be able to get away with using the 40 amp fuse alone, or do I need to wait for the double fuse holder, and put both of those in line with the positive side of things?
Looks like it... mebbee another owner can confirm.mlrosier said:Is it suppose to be under the board to prevent the bottom welds from contacting the housing?
There should be a thread regarding water blocking here somewhere.
lazarus2405 said:Sounds like a bad battery connection somewhere. Ride the bike until you reach your LVC, then go charge all the batteries individually. If my suspicion is correct, three will be dead and three will be fully charged. In this case, you'll have a bad solder to one of the packs.
Would this be why the CA is showing only 3Ah when I'm at a dead standstill with the power on?
When you say you're getting 5 miles, are you sure your batteries were all fully charged first? And how hard were you riding?
Yep, my batteries were fully charged. Charged them up lastnight before I went to bed.
Regarding the setup of the CA, there are a few kinks involved. First, the Rshunt in the advanced settings needs to be calibrated one way or another. If that's not set correctly, everything derived from the current measurement (current limit, amp-hours, watt-hours, watts, amps, etc) will be thrown off.
If the RShunt is too low, it will prematurely limit the current, and it'll feel... well, puny. I had this problem initially, and I could barely keep up at 30mph. Very bad when riding in traffic. If the Rshunt is too high, it'll show a much lower amp draw than normal.
Try unplugging the CA and ride a little. If it feels torquier, with more acceleration, and higher top speed, then the CA is prematurely limiting, meaning that because one limit or another it is sending a throttle override signal. If that's the case, run without the CA for a couple miles and you'll really have an ebike grin!
Does anyone know a good RShunt setting for the clyte v2 controllers? From the v2 information thread it sounds like a good value for a 48a controller might be 5.4miliOhms, but it seems awfully high. A typical shunt measures ~1mOhm.
Back into unfamiliar territory for me. I don't know what you mean by RShunt. Also, has anyone put an inline on/off switch between their C/A and Controller? If so, can I see how you did it? Rather than having to unplug everything, I'd love it if I could put an On/Off switch in.
Also you said that I should put the Amp limit over 50amps, but then said you had fun on 10amp. I'm confused. lol. Honestly, sometimes it doesn't take much to confuse me. Also, how would I go about testing for a bad battery connection if there is one present?
Yep, my batteries were fully charged. Charged them up last night before I went to bed.
It's harder than crap to get the batteries as they are now, into the bag on the rack, and because of the tight fit, the Anderson connectors are breaking connection in the Series of batteries.
How hard would it be to dissect the packs and make one or two battery bricks? Would I be able to charge it with the Milwaukee Charger? Would I be able to get away with using one BMS for all of the cells if I did just one block, or would I need to do two blocks with two BMSs?
