e-beach
Jabotical said:Sounds like a valuable suggestion. And you're right, since I'm getting a new wheel anyway it may as well be disc brake compatible. The rim brakes so far have seemed to be plenty effective, but maybe that's in large part because I've got a DD with regen braking that's doing a lot of the work.I would never let a friend ride an electric bike without at least a Front Disc Brake. There is no comparison in the stopping power of a well adjusted good disc brake and a well adjusted V-brake. Remember you are normally traveling about 50% faster than a regular bike---my estimate.
And I never let a friend ride an e-bike with a well adjusted front brake. Why? Because if you lock up that front break you either skid in a straight line right into the object you are trying to avoid, or you washout an crash, or if you lock it up and the inertia of your bike rolls over the outside of the wheel, you fly over the handle bars.
How do I know? I've done all three.
I recommend having the front break just loose enough to be able to pull the lever hard and still have the wheel turn enough to steer away from trouble. The back break should always be able to lock up. I use v-breaks and keep my rear wheel trued so it can always lock up. If you have disk breaks, you don't need to true the rim so often.
