spinningmagnets said:
my l-r kit contains the prototype lower and upper sheets which got twisted due to too much torque, however due to apparently posting too many messages and questions in the build thread which deemed too basic by the rest
I'm going to do my best to be open and fair to you, Emayaan. As of today,
you have posted 505 times in the LightningRods mid drive thread. This doesn't even count the mind-boggling number of PMs you have sent to LR and me (hundreds of PMs...
HUNDREDS). Mike has chosen to block seeing your posts, and that is the reason he doesn't respond when you post.
Many months ago, I publicly posted in that thread that the LR kit was not the right system for you, but you insisted on experimenting with it. Other builders (there is an index in the second post) have run
more power than you through this kit, without any of the type of damage you describe, and have posted pictures of. from that fact, I can only assume you did not properly adjust the brackets. I'm sure you thought you had assembled the system properly, but the results speak otherwise.
I can sympathise with your situation, because I have also performed many experiments with new products, and...I sometimes broke stuff, then posted the results so that others could see the performance limits of the parts. I'm a firm believer in free speech (notice your posts haven't been taken down?), but...I also have that same freedom.
I hope things work out for you with the 60V chain-primary GNG, perhaps you will have better luck with it. However, I have a word of advice for you. If you send Jon Chan 505 emails, he will no longer respond or sell parts to you. I'm not trying to be mean or petty to you, but I do want to be clear about what happened and how the current situation resulted.
i'm respond to this post because .. well i just saw it... this is very strange, i never saw it earlier, as a moderator do you the ability to insert messages in a middle of a thread?
second, i didn't even KNOW there's a block possibility, had i known , i might have guessed it was used.
now let's address the L-R situation
1. my requirements were simple, a 1500-2000 mid drive with 50-60 kph and good acceleration, be more efficient that my current drive, and not burn out custom parts. by all parameters the kit did fit the bill, so why wasn't it "right" for me? complexity in installation? how do you measure that until it's too late? would L-R need to give "exams" for new customers? what will happen if another one runs into problems and exceeds the "limit"?
2. yep i did write a lot of posts, was any of them berating? insulting? hurtful? did i say at any point the kit was bad? not to my memory, what i did do , is to be the first one to try out if the thun sensor work on this kit, i distinctly recall that both l-r and others were waiting to see the results, , i didn't say there was something wrong with the kit when it didn't fit,i was just disappointed , and moved on . i also always defended l-r when he run into production problems when i waited for my kit for 6 months, even when it reached a point where some folks were starting too wonder if this was a scam, i was one of the people who said this was due to "first time" production line problems, i knew l-r didn't test his kit, but i still pressed on, because i believed in it.
every time l-r posted news about advancement i would quickly like it, share it on my facebook page, an e-bike group i was member in, and would encouraged others to do the same, just to spread the word as much as possible, the same with your article.
when i run into problem installing the bb , i again didn't blame the kit, but L-R called it the "emaayan effect" thinking i wasn't installing it right, when it turned out there wasn't enough threads in the bb shell to begin with (because i had a custom frame) i resolved that problem as well. but l-r seems to think that everything i post "damages his fledging business" as he put it. would you buy something from someone who says "sure, i'll sell you, so long as you don't post anything i think is bad or too much of anything"
should i be afraid every time i ask or post something?
3. regarding the twist, i would jump at the chance to label any problem i encounter or would encounter as my own private case, rather then a problem with the kit, because that would mean it had a solution or a fix, actually i was surprised to see those problem occur in the first place, because my original assumptions was those sheets were out there already before the entire kit, so they must have worked so far (it's was only the kit that was published entirely recently) , but , when i saw other posts with the same issue where the lower sheets would slide back now matter how much you tighten the bolts, where others like jdevo experienced the torsion problem, even a computer stress analysts was published on the model, and when L-R finally released thicker sheets with bigger bolts, then i had to conclude this was a problem with the kit, so maybe i didn't run at high power as the others, maybe it was weight or the bike. but it WAS a design flaw. it might have not turned out on all use cases, but it did turn out on some cases other them my own. which weren't due to installation problems.
but even then, i said "ok, so there was a bug in the design, it can happen, i'm willing to PAY for more parts and better ones" didn't make much of an issue from it. which i was pretty sure clarified how much i believed in the product.
people are coming to get l-r kit from all over the place, can you be sure that it's "right" for each and every one of them? like i said before on the "beast" thread , when matt from astro kit warned me that his kit is not "bolt "on i detailed all my experience with ecospeed and the motor fixes i did, he seemed rather at ease saying i'm able to handle his kit, naturally he seemed much less sure about it, months later. which just goes to show you, you can never be certain, the person you are selling will get it right the first time, so what's the solution? block them if they write you too much and refuse to support them after they paid you? i'm pretty sure most people at this point will not be so poised like i was. so may be they wont' post 500, may you'll get 3 people posting 50 times?
and l-r calling me a boy, posting fatal attraction meme's? while the rest are laughing and calling me creepy? , yea, that's a really mature way to handle it. it also borderlines on cyber bullying.
and it would take one or two to start raising hell. but i guess i'm easy target.
i don't know what jon is like, i get the impression, he's very focused, concise, and probably doesn't care at all at what anyone writes about him in any forum, he just sells stuff. he only answers questions which have clear an precises answers. ignores everything else, i get that. it's understandable.
regarding the gng, i did manage to install it however ,lantice13 , i run into problems regarding the bb. this time it's not a threading problem (trek 7.7 all threads are there), but to my knowledge the bb installs when detachable cup is on the left side (left side when you face the bike from behind) , however that placed the longer side of the shaft on the left as well, which didn't make much sense as this is the side is where the crank and pedal are running through. i also see the same here with sick bike parts http://www.sickbikeparts.com/catalog/product_info.php?cPath=23&products_id=107&osCsid=c6aqgh158i1m8fsnsost9mv4f7 bb, my machinist said you can't screw the bb from the other side, (from right to left, as the threading on the bb won't match the shell). so what gives?
i disabled the tensioner as it seemed to actually be causing the chain to drop, i ordered something similar to lantice (as the shop he pointed out wouldn't ship to israel) http://www.ebay.com/itm/391093848717 i'll see how it works.
[youtube]pPs_IOHzUD0[/youtube]
