crossbreak
skyungjae said:Bzhwindtalker was able to get 4.5kW out of the motor, but he took it apart and doubled up the phase wires.
Really? you mean output power? that must be ~7kW input power? and about 2.5kW loss
my converted Bafang 24V SWXB does 1.8amps@46V, that is 83Watts in first gear and ~2.1amps in highest gear (that is 550rpm or 67kph). Got crappy $20 disc brakes that slip a bit.meelis11 said:Can you guys lift off wheel and give full throttle and see wattage?
jk1 said:by flyinmonkie » Sat Aug 24, 2013 7:21 am
If done right, chain is not noisy. You need to stay away from small sprockets and get it aligned well.
Why would you say that when Christerjung has just done a high voltage GNG chain drive and it is noisy as an RC motor, maybe even more then a cyclone as RC motors were know to be noisier .
Re: New freeride project - LMX P1
by bzhwindtalker » Sat Aug 17, 2013 7:50 am
the Stock GNG is quite silent but the combinaison of 100v and #25 chain mod makes it sound like most RC drives.
http://endless-sphere.com/forums/viewtopic.php?f=28&t=47054&start=150
flyinmonkie said:Until you have ridden a bike with a proper chain set up and heard it first hand, then you can't say it's loud. I would say there is more motor whine than chain noise in any well set up chain reduction.
Clay
crossbreak said:skyungjae said:Bzhwindtalker was able to get 4.5kW out of the motor, but he took it apart and doubled up the phase wires.
Really? you mean output power? that must be ~7kW input power? and about 2.5kW lossI thought this one must melt within minutes!?! On which dyno was this awesome power measured and how long continuously? Even more interestin, at which rpm band? such an output power seems impossible for me :?
arcticfly said:So If I buy this with the LR sheets, what else do I have to change/buy to get this reliable? aiming at 2000W. Assuming the chain is holding up of course![]()
THX!skyungjae said:
speedmd said:The other I am hoping to sandwich into the cdale if there is any way to do it without destroying the kit.
spinningmagnets said:Wishes, the chain looks like it might be #35. Could you do me a favor and count off ten pins, then measure the distance between them? Inches or mm, either would be fine...
