Update 25.04.2020
Well ladies & Gents,
I thought it was about time a gave an update on my Electric pan project to date.The first thing I did back in January was sent the frame, sub frame, swingarm and the centre stand away to be sand blasted and powder coated.
After this I then started to assemble all the parts back together to form the outline of a bike again.
First the swingarm. It took me a while work out how much gap on each side to, I think this is correct. (please let me know if I got it wrong. Could not find the gap in the Manual.)
The next task was to fit the yokes, folks, rear Maxton shock, foot peg brackets. The windscreen motor drive assembly is now removed as it will save power drain from the batteries, I plan on having a static one position screen.
I have also at this point started to refit the front brakes, which will be non-ABS system, to save on power demands again.
Now on with the rest on the brakes and fill up with DOT 4 and bled accordingly.
Once all the brakes were bled, the fitting of the rear light, tail section, tank, tank lock, panels, seats and rear drive unit.
In an effort to save as much demand on the battery as possible and reduce any potential demands on power. My plan is to
Convert and the lights to LED’s
Trim the harness down. Future update to detail further.
The drive train and shaft are to stay very much the same. I plan to fill the splined universal coupling by either welding, chemical metal, or brass. this will assist with connection to the Keyway shaft fitted to the electric drive motor I intend to use.
The Planned next stages are:
Trimming down the wiring harness, removing all the redundant functions like the:
Ignition system, coils & CDI.
ABS braking system & ECU.
Starting motor function.
Alternator
Relays block
Changeout the Indicator relay for LED unit.
incorporating the DCC to DCC unit to feed direct from the New Main Battery.
Fuel Injection system, pump and gauge
Clutch switch.
Transponder system for ignition key.
Lombard sensors (exhaust)
Air flow sensors
basically, so the functions left from the original harness will be:
Ignition switch and key
Indicators (now LED)
Front Light unit (now LED)
Brake lights (now LED)
Side stand switch
Side lights (Now LED)
Run / Stop switch.
Light switch.
I am still on the lookout on eBay for the following:
RH lower blue fairing
RH mirror cover in blue.
Bikini top fairing in blue.
Headlight unit.
Then the design on the 20kw motor & battery Cage, which is now where the original ICE engine is. I decided now just to the electric battery and motor route, for ease. If down the line, after I finish bike, I may revisit the ICE conversion, as I still deep down believe I could utilise the gearbox, crank and clutch as previously though. But this will be too involved for now.
The thoughts I have for the motor and battery cage, will be a strong 25mm thick aluminium back plate, to which the 20-kw motor will bolt direct onto. This back plate will secure in place the modified spine coupling onto the drive. the area in of the motor will be the area that I fit the 14 Nissain Leaf LI Ion batteries, or similar with the a BMS fitted.
The Li ion Batteries from the Nissain leaf will be stacked ontop of each other.
each battery is technically a 2s2p
nominal voltage - 7.7v
fully charged - 8.4v
Fully discharged - 5.6 v
amp hour 64
Watt hour 500WH
continuous discharge 240A
Peak discharge 540A
therefore 14 of these modules i am expecting
96v , 896ah , 7000Kwh
The Fuel tank will first have the underside cut out, and Sevcon controller will be mounted inside on a PDM backing board for insulation. I also plan to fit some sort of charging plug into the fuel cap area.
All these ideas, at the moment are still fluid, but as I commit to a design or revise it, I will post pictures and the thoughts behind it.
If anyone has thoughts on the range i will get with the 20kw motor I have ??????
Also some suggestions on a BMS and a charging system ??
Please let me know, as more minds are better than one.
I have the base design laid out to work from...
Stay safe
tony
