sl33py
okp said:hey there, I am considering the vacuum pump, I am actually molding many pieces but it's a pain to make the carbon fiber stick to the mold perfectly.
I used a clothes vacuum bag with a hover yesterday.. it was nice but it didn't kept the pressure. I want something more professional than this hover stuff which was a fail. Result is OK but impredicable.
I will also use it in my upcoming project with a CF deck.
do you have any thought on this one : http://www.ebay.fr/itm/3S-POMPE-A-VIDE-CLIM-FRIGORISTE-DOUBLE-etages-42-Lt-min-electrovanne-vacuometre-/190680830797?hash=item2c6576934d ;
it's 150 euros in France but I found this one in Italy, same price but has some additional pieces
http://www.ebay.fr/itm/3S-KIT-POMPE-A-VIDE-42-Lt-min-MANIFOLD-UNIVERSEL-MANO-CLIM-R410A-R407C-R134A/141563299536?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D20140620091323%26meid%3D19bb052efb784a7cbe200aded90855da%26pid%3D100005%26rk%3D1%26rkt%3D6%26sd%3D110769285183
I will have also to get the vacuum plastic bag and some additional sheets.
I would definitely skip the one with additional pieces. All of those pieces are specific to AC/refrigerant - in other words not very useful. The biggest pain of getting the pump setup to use was getting converters and the pump setup to go to a regular hose barb so i could run vacuum to my bag/table. The converters from coolant connectors is a pain and i'd avoid it. I ended up taking the whole threaded adapter out of the pump and replaced it with a standard NPT fitting to go to my vacuum gauge and hose barb.
Another thing - 42 (L / minute) = 1.483216 cubic feet per minute. 1.5 CFM is pretty slow. I don't think i'm using my pump efficiently at this point, but i wouldn't want a slower pump unless it was significantly less expensive. For ~$150 i think you should get a faster speed pump 3/5/+ CFM. (70-100L/min)
I have found that correctly sealing the membranes with butyl tape was the best way to keep vacuum pressure on the part. If you shut off the pump for a minute and listen while you feel the edge of the membrane/tape - it's usually pretty easy to hear and find the leak.
what membrane and other materials are you looking to get?
