Bazaki
- Joined
- Dec 25, 2009
- Messages
- 639
People,
I really love to ride my Ebike 18s 2p Lipo 66,6v 10ah battery set at 80 amp lyen controller at a Crystalyte High Torque motor. 85 km/h top speed and very very good acceleration.
This year I rode about 2300 km with it. I also ride with my 2 year old daughter with the ebike. ( speedswitch 1 set at 25km/h ) Also my wifes rides the bike.
BUT, I have seen some dangerous things, ofcourse we all know about the Lipo-fires, so in case of a fire we all must get away from the ebike.
Another point danger is the throttle, a week ago I was cleaning my Ebike in the garden with hose, just a small amount of water came inside the frame-bag so the throttle connector got a bit wet, the Ebike was switched on and also it was set at Speedswitch 3. So 80 amp 70v and the bike flew away. No accidents and nothing broken. Also sometimes I have seen that My speedswitch is set at speed 1 but sometimes it rides at speed 2, because if there is no 3-way speedswitch connected to the controller, the controller will perform at speedswitch 2 set at the software from the controller.
So full throttle at speed 1 with 100% throttle ( 25km/h) and with suddenly a lose connection can result in 100% throttle at speed 2 which can result in a very bad wheelie.
An Ebrake won't help it is too fast, also with some water ( rain at/in the throttle/connectors) that can result at 100% power, also I would go 60km/h and some how the throttle will hang at 100% I don't think my brakes are strong enough to stop me from having an accident. A good ebrake will be a solution but I want to be 100% sure that this will work so I have thought about the following solution.
I did some tests and 70V with 30A will not result in an unwanted wheelie so, I was thinking to install an Automatic fuse of 30A in parallel of the main on/off switch. So I want to ride safe with my daughter or someone else will ride my ebike, I leave the main switch at off and set the automatic fuse of 30a at on. One can ride the Ebike normal with still 2000 watt of power, but be a bit easy at the traffic lights, accelerate gentle and everything is fine. But as soon as so accelerate too fast then "CLICK " the fuse switches the power off. You can install it near the battery and switch it back on.
So when I ride in the rain, or something else will happen the power is always 100% off above 30A.
70v x 30a is still 2100 watt which is good enough to ride about 65km/h but as soon as I would hit the brake the Automatic fuse switches off beacause you would drain to much amp.
A few friends of mine that build an Ebike with the same setup all have had an unwanted wheelie, 1 of them with a broken foot, he thought the speedswitch was set at speed 1 instead of speed 3.
I think the Automatic fuse solution can prevent a lot of unwanted wheelies, I have to do some more testing because I think there is a small delay in the Automatic fuse.
Any thoughts ?
Any thoughts ?
