Unique. Here's some lifted pics and info for when the ebay post goes away...
Originally a 2012 Felt MP beach cruiser... A 50 tooth rear sprocket gives the gas motor a top speed of 35-40mph with a 200 pound man in the seat on level terrain. Top speed for the electric hub alone is 25-30mph. When both motors are used simultaneously, it is capable of climbing the steepest hills without pedaling and able to pull away from a dead stop at car speeds.
Bike:
2012 Felt MP
Motors:
Huasheng 49cc 4-Stroke C.A.R.B. Approved
Crystalyte HS3540 Direct-Drive Hub
Clutch:
Fully Automatic Centrifugal EZM Q-Matic
Batteries:
AllCell - Lithium Nickel Manganese Cobalt 48V 12.9Ah (Housed in right hand ammo can)
Phantom - Lithium Ion 12V 14Ah (Housed above front fork)
Controller:
Crystalyte 40A 12 Mosfet Sensorless (2000 Watt)
Brake:
Tektro - Auriga E-Comp Caliper (hydraulic)
Tektro - Hard Ceramic Brake Pads
Shimano - Ice Tech Front Disk (203mm)
Tires:
Geax - 24" x 2.3" Tattoo Rigid
Lights:
Rear Dual PDW - Danger Zone
Front 20 Watt CREE LED light mounted inside a Hella 500 light housing
Horn:
Wolo 139 Db 12V Air Horn
Throttles:
Electric - Left Hand Thumb Throttle
Gas - Right Hand Twist Throttle
Seat:
Harley Davidson bobber style, genuine leather, motorcycle seat
Seat Height:
28" (fixed)
Battery Range:
Batteries alone: 20 miles (no pedaling)
With gas engine running: 60+ miles (no pedaling)
Fuel Capacity:
3/4 Gallon
Weight:
100-120 pounds (estimated)
Top Speed:
35-40 mph (level terrain, no pedaling)
