steve2777
I'm replacing my Hyper ebike 3 level controller, and have taken forum members' advice to go with KT products. I have installed a KT36/48ZWSRD controller and KT LCD-C display, as well as a thumb throttle. Display turns on and the settings and assist level adjustment work normally. The display shows when I activate the brakes and throttle, so presumably wired correctly. But when I pedal, there's no assist, and when I press walk assist, display shows "motor position sensor fault!" (I did replace the motor cable, as original was cut in a previous install; Is it possibly defective?) Bike already had operating PAS with 12 magnets, so no changes there. PAS to controller wiring is red>brown, yellow>black, blue>yellow. I'm at a loss as to the next step. Any help is appreciated.
