mellingford
🧲 New user
Hello everyone I have a Cyrusher XF650.On throttle and PAS it started making a loud noise and vibration and would stop and not start again, moving wheel backwards it would start again but with noise again, me thinking must be hall sensors if starting again in different positions, replaced hall sensor circuit, made no difference, on closer inspection the noise and vibration was coming from the area where the controller is situated in the downtube, removed the controller too see if anything was loose, tightened all the screws still the noise.There is no moving parts in the controller can't understand why it's making so much noise, will dismantle the controller and check Mosfets. What do you think?
Cheers
Cheers
